back window not working
Old Sep 2, 2018 | 08:29 AM
Mr177's Avatar
Mr177
Default back window not working
I changed the battery in 04 es330, restored settings, but the back windows do not work at all, even on the back door. and master is not on lock
Old Sep 2, 2018 | 09:47 AM
flowrider's Avatar
flowrider
Veteran: Air Force
You have posted to the wrong forum. You would be posting here:
https://www.clublexus.com/forums/es-...1990-2006-179/
However, try rolling down and up each window with the switch at the window location. That should reset the windows to work with the master switch at the driver's door.
Lou
Old Sep 2, 2018 | 03:08 PM
Mr177's Avatar
Mr177
Lou
Thanks but I tried that, I can't get the switch to work no where.
Old Sep 4, 2018 | 07:14 AM
funcrusher's Avatar
funcrusher
Common issue. Sit in the backseat and close the door hard while holding down the window switch.
Old Sep 4, 2018 | 08:28 AM
Mr177's Avatar
Mr177
Thanks funcrusher, just tried that and that didn't work either, but I do notice that I hear a click when I move either switch, so I know the switches are working. I guess its time to take to the dealer.$$$$$$
Old Sep 4, 2018 | 10:32 AM
wmj259's Avatar
wmj259
You could try hard powering the window motor to see if that works. This would require removing the door panel. Taking a 12v battery and wiring it to the motor connector.
momof1
Sep 12, 2017 04:41 PM
PanicUnit
Maintenance
Aug 20, 2010 08:23 AM
cmarsh
GS - 1st Gen (1993-1997)
Sep 26, 2009 05:32 PM
bfigard
Dec 7, 2007 03:34 PM
