2000 RX300 Engine Replacement
Old Sep 28, 2022 | 02:29 PM
Mfrankster's Avatar
Mfrankster
Default 2000 RX300 Engine Replacement
This is a series of videos I've done as a guide for replacing, removing, refreshing the engine in a 2000MY Lexus RX300.
The first video covers removing/dropping the engine from the car. In the past, when forced to do so, I have pulled the engine out the top. But whenever possible, I prefer to drop the engine with the transmission on the engine cradle subframe.
Old Sep 28, 2022 | 02:32 PM
Mfrankster's Avatar
Mfrankster
In this video I cover the important differences between 1MZ-FE 3.0-liter engines found in different Toyota models. The most important differences:
1. FWD vs 4Wd - the block is different.
2. RX300 vs Highlander - the oil pump and timing belt components are different.
Old Sep 28, 2022 | 02:33 PM
Mfrankster's Avatar
Mfrankster
If you have purchased a Highlander engine, or other engine with the same timing components, you have no option but to remove the oil pump and replace it with a RX300 compatible oil pump.
How to remove the oil pump:
Old Sep 28, 2022 | 02:34 PM
Mfrankster's Avatar
Mfrankster
How to install a new oil pump:
Old Sep 28, 2022 | 02:36 PM
Mfrankster's Avatar
Mfrankster
Bonus track 1: How to remove and re-install the camshafts.
Old Sep 28, 2022 | 02:37 PM
Mfrankster's Avatar
Mfrankster
Bonus Track 2: Elaboration on the all-important service bolt that many people overlook, with dire consequences, when servicing the camshafts.
Old Sep 28, 2022 | 02:38 PM
Mfrankster's Avatar
Mfrankster
Bonus Track 3: The head gasket.
Old Sep 28, 2022 | 02:39 PM
Mfrankster's Avatar
Mfrankster
And of course when you do all this, you have to do the timing belt, so here's another bonus track. Enjoy!
Old Sep 28, 2022 | 02:48 PM
Mfrankster's Avatar
Mfrankster
This is not really about the engine - it's about replacing the radiator. I've seen a few videos that suggest an incorrect way of removing the radiator. Here I do it the right way.
Old Sep 28, 2022 | 02:52 PM
Mfrankster's Avatar
Mfrankster
And while we're at it, a quick guide to the ball joints, that can be perplexing if you're not used to this sort of thing.
Old Sep 28, 2022 | 06:29 PM
maxSteel's Avatar
maxSteel
Nice set of videos on your YT channel. Everybody should throw you a sub.
Note the last two in this thread are showing as private - they might look different to you.
Old Sep 29, 2022 | 12:00 AM
Mfrankster's Avatar
Mfrankster
Sorry, those last two videos should be public in a day or two.
Old Sep 29, 2022 | 07:58 AM
salimshah's Avatar
salimshah
25 Year Member
Please leave a link in the DIY thread. Remember the DIY thread is just a launch point/index and the actual DIY should not be posted there.
Salim
titang9
Aug 19, 2021 05:10 AM
Damyan7
Jul 13, 2021 10:11 PM
jaybarbara
NX - 1st Gen (2015-2021)
Nov 5, 2018 04:40 PM
metaron
Mar 30, 2013 07:54 AM
daryll40
Dec 13, 2011 09:56 AM
