transmission question
Old Mar 15, 2019 | 04:57 PM
21bigblock's Avatar
21bigblock
Default transmission question
Hello I just went through putting new plugs and coils on along with new valve cover gaskets. I got it all back together runs good no codes but now the transmission wont shift from 1st to 2nd for an extended time and then when it finally does it shifts extremely hard. Is it possible I may have unhooked something electrical to cause this? Thanks for any and all input.
Old Mar 15, 2019 | 06:38 PM
TrueGS300's Avatar
TrueGS300
Did you have the battery disconnected? You may need to reset the computer by removing both battery cables and holding them together for a moment. Loss of battery power can cause several issues in these cars. TCM may see the loss as a problem and malfunction until reset.
Old Mar 16, 2019 | 07:23 AM
hypervish's Avatar
hypervish
Sounds like you may have forgot to re-attach the ground cable behind the intake manifold. I did the same thing and had almost identical symptoms.
Old Mar 25, 2019 | 08:12 PM
rx4rr's Avatar
rx4rr
Have similar problem: immediately after changing injectors I have rough & delayed shifts, primarily 1 to 3 & 2 to 3 and down shifting. No display warning. Is it solenoid or connection to solenoid?
marjaz
Feb 11, 2020 07:02 PM
atticusgre
Dec 31, 2018 11:46 AM
gindyo
Jun 27, 2016 07:31 AM
jjbenzo
Feb 7, 2010 12:12 AM
cybrstarr
Performance
Dec 16, 2004 12:42 PM
