Tie down hook?
We have had so much rain and where we park is dirt and gravel. I worry about getting stuck in the mud. Is there a rear tie down loop I can use for pulling the car out of the mud if necessary? I can find the one on the front but can't find anything on the rear.
https://images.etrailer.com/static/i...300-41541.webm
There I tie-downs and tow hooks. Both allow tethering opportunity but only tow hooks should be use to pull [pull something or get pulled].
By default there is no tow hook on first gen RX, but there are tie-downs. In a pinch, I would suggest use both to split the pulling force. I removed the rear tie-down and installed the hitch, and I had to use an extra bolt and the hitch got attached to both the left and the right side.
Salim
Salim
I checked and both of the rear tie down hooks are missing. I wouldn't mind replacing them If I can find a source. The local PnP doesn't have any so if anyone knows where I can get them let me know.
wilchan
RX - 3rd Gen (2010-2015)
Nov 30, 2012 02:38 PM
