Trip Information Problem on Navigation System?
Old Jul 16, 2003 | 06:47 PM
stevech's Avatar
stevech
Default Trip Information Problem on Navigation System?
On the Navigation System, when I check the Trip Information (Fuel Consumption) screen, I noticed that the DISTANCE TRAVEL gets reset to 0KM or 0MI everytime I start the engine. According to the Navigation System Manual it states that the DISTANCE Travel gets reset to 0 after every fill up and not everytime I start the engine. Does your RX330 with NAV reset the Distance travelled after an Engine start or after a fill-up.
In other words do I have a problem or not?
Regards and Thanks in Advance,
Old Jul 16, 2003 | 09:28 PM
jeffknet's Avatar
jeffknet
you're confusing the CRUISING RANGE with the CRUISE DISTANCE..
Cruising Range is how far you can travel before you need to refuel - and that won't reset until you refuel
Cruise Distance is how far you've traveled since your vehicle has been started - if you turn the engine off it will reset to zero once restarted
Old Jul 17, 2003 | 06:02 AM
stevech's Avatar
stevech
Thanks Jeff. I appreciate the input. I was confused by the manual.
Old Feb 10, 2008 | 11:06 AM
Momzinator's Avatar
Momzinator
Is there a way to set it so it doesn't reset everytime you turn it off?
cklh2000
Oct 27, 2013 12:34 AM
tomd
Aug 3, 2012 03:20 PM
lofidelity
Nov 14, 2011 06:24 AM
Kyoto
Mar 7, 2005 08:55 PM
looknow12
GX - 1st Gen (2003-2009)
Jan 10, 2003 11:10 AM
