1999 Lexus RX300
Old 07-20-17, 08:29 PM
trhs75
trhs75's Avatar
Mark,
Someone on this forum one mentioned to differentiate between an actual remanufactured transmission (such as done by Lexus) and one which is merely rebuilt. Maybe check on that, too!
Old 07-20-17, 09:33 PM
SVRX300
SVRX300's Avatar
Originally Posted by JosephP
Hi Svrx300
I just bought a RX300 for my daughter and I have the door lock issue, I don't know where to look. I posted on my 1st post and waiting for a reply, but unfortunately I don't get any help yet. The lock, unlock, panic not respond when buttons pressed. The rear passenger door can not lock manually, unlock the passenger by the key, alarm goes off. but the driver door ok. Since you have lot of experience on this car. I hope you can help me where to look. I have electrical and some mechanical back ground
Thanks in advance
Joseph
Hi Joseph, It's been a few years. If I remember correctly, the door lock didn't respond to my remote control lock/unlock. I took off the door panel and found the linkage (cable?) was broken nearby the lock mechanism. I cut a certain length piece from the metal clothe hanger, shaped it, one end connected to the factory cable broken end by making a tight "U turn" on each piece then hooking them up. The other end of the new added piece goes through the lock thing which is difficult to explain but you will know once you are there. It is not too difficult to fix. If the broken end is in a difficult point, you can cut factory cable even a bit shorter to bring the "broken" point to a more convenient point. The joint point should not be blocked by anything when the door is locked/unlocked. The travel distance is about half inch I guess.
Hope the above helps a little. I will be checking back this thread often so please let us know your progress.
Old 07-21-17, 06:59 AM
salimshah
salimshah's Avatar
I dont think Lexus remanufactures the transmission. They most likely contract remanufacturing.
Salim
calgarylex
23
09-06-18 08:21 AM
shadow2121
04-09-17 06:22 PM
ValCapone
16
09-02-10 08:04 PM
krazie604
11-07-09 07:49 AM
danlaws
17
06-25-07 06:43 PM
Quick Reply: 1999 Lexus RX300
