When do coil packs fail?
Old 09-02-09, 07:07 PM
AlexusAnja
AlexusAnja's Avatar
Default When do coil packs fail?
Okay, I'm about to go into the dealer for my third coil pack failure (most likely the cause). My first coil failed about 97K, seconds around 115K, now at 123K another. I'm assuming it will be a different coil pack that the two replaced already.
Anyway, when do these things typically fail at? Am I just having some bad luck, or they fail around early 100K? I'm asking because I'm considering replacing the four at this time, than to wait for next to fail.
I've been lucky that the ones that have failed happened to fail while I was close to home, or at work. But what if it's 1/2 way through a vacation?
Old 09-02-09, 07:24 PM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
I've only had one fail (right around 100K by my memory), and that's pretty much because I botched a job on cleaning the intake manifold with a bit too much cleaner. Other than that they've run fine. I'd check the gap on the spark plug under the coil in question, but also see how clean the plug is.
Old 09-02-09, 07:39 PM
AlexusAnja
AlexusAnja's Avatar
Default Plugs
Plugs are one thing I don't care to tackle myself, so if nothing else, I've been too quick to replace them. I had my first set replaced at 58K, then again at 115K when my 2nd pack failed.
Can I say that for whatever reason, the coil packs then are prematurely failing on my RX?
I guess I should proactively replace them then...
Old 09-02-09, 07:43 PM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
What I am saying is check the gap on the plug underneath the coil in question, not changing all of them, sometimes too much of a gap can cause an issue.
Whenever I did plugs with my uncle and cousins using single prong plugs (like most plugs), I'd always check the gap on them, because even though they are new, sometimes they aren't gapped properly.
Old 09-02-09, 08:02 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
My view about things that are manufactured together have close to the same life. So if one coil-pack goes bad, it is very likely the others will go. So if one fails it can be an anomaly but if more than one fails the chances are the lot will have similar life.
Incidentally, one of my coil-pack failed immediately after I installed new plugs [140k miles]. Since I have longer arms, for me replacing plugs gets 2/10 in difficulty. [changing oil filter is 3/10].
Salim
Old 09-03-09, 09:25 AM
sktn77a
sktn77a's Avatar
I had one coil go out at ~100,000 miles.
Old 09-03-09, 10:20 AM
lexus114
lexus114's Avatar
I`m sure it was one of the rear ones correct??
Old 09-03-09, 10:51 AM
UNOHOO
UNOHOO's Avatar
i had 2 go out in the rear, i changed the rear 3 and then a couple months later did the front three, wouldve done it all at the same time just couldnt afford it at the time
Old 09-03-09, 01:02 PM
TunedRX300
TunedRX300's Avatar
The front ones are easy to do, if you are concerned about cost, just use the old but working back ones as spares.
I plan to replace the back one that is hardest to reach with a new coil pack when I do the spark plugs in the next week or two. Use the old but still working one as a spare, keep it with couple of hand tools in the car.
Old 09-03-09, 02:29 PM
AlexusAnja
AlexusAnja's Avatar
I'm taking the opinions here to be that I should check the gap first (dealer will do that), but that I should probably replace the remaining four.
My whole deal is, the three failed when I was close to home. I don't want one failing when I'm like 200 miles from home and I have to scramble looking for a shop/dealership to fix and lose one day hanging around (even with loaner).
Thanks guys/gals (if there are any).
Old 09-03-09, 03:30 PM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
Always in my RX300, I still keep an OEM coil and also that one I modified from a Camry coil when I lived in Mexico.
Old 09-03-09, 07:15 PM
sktn77a
sktn77a's Avatar
Actually, I don't remember (erased from my memory - a side effect of the size of the check I had to write)!
Old 09-04-09, 06:21 AM
lexus114
lexus114's Avatar
dont count on the dealer taking too much initiative,my trunk monkey would probably do a better job.
Old 09-04-09, 10:08 AM
TunedRX300
TunedRX300's Avatar
Smart, was it the front one that failed on you? I remembered you said the middle back one is the hardest to reach?
Old 09-04-09, 11:02 AM
Lexmex
Super Moderator
Senior Moderator
Lexmex's Avatar
Yep, it was one of the front ones. The front middle one if memory serves me.
Quick Reply: When do coil packs fail?
