Solar Sensor, how to remove
Old Jul 5, 2016 | 08:46 AM
BobQ's Avatar
BobQ
Default Solar Sensor, how to remove
I get a DTC 21 which is the solar sensor. RX300 2003 and 120kmiles.
Tech service bulletin TSB2072 has info for testing various sensors but lacks info for how to get the dang thing out. Sitting in the driver’s seat it is just to the right of the light sensor (dims the instrument lights at night).
I can get the lid (cover) off the top but then I have no idea how the rest comes out. I hope it lifts upward vice going down into the vast maze behind the dash. What is the procedure?
Also the
If the solar sensor is bad, what kind of symptoms should I have?
Bulletin TSB2072 lists four variations of the solar sensor based on if the car 1: [is equipped with automatic light control system] and/or 2: [AC with Left/Right independent temp control] To my knowledge the RX300 does not have a Left/Right independent temp control but I think it does have an automatic light control system.
Given the Solar Sensor will show infinite resistance at night and some conductivity in sunlight. Shouldn’t the AC continue to blow cold either way?
Old Jul 5, 2016 | 09:07 AM
salimshah's Avatar
salimshah
25 Year Member
Be careful with the solar sensor error message. Everything can be OK.
Some one please confirm or correct me:
If the self test is conducted in a garage (covered area), you will get a fail.
Salim
Old Jul 5, 2016 | 09:38 AM
BobQ's Avatar
BobQ
thanks, I was outside, direct sun on sensor. BUT I'm not going to a lot of effort regarding this sensor since my AC is working but not on the passenger side.
Old Jul 5, 2016 | 09:41 AM
BobQ's Avatar
BobQ
ALSO: My main question is how does the solar sensor come out?
Old Jul 5, 2016 | 07:30 PM
carguy07's Avatar
carguy07
Looks like it just pries out.
Old Oct 5, 2022 | 08:25 AM
derreckla's Avatar
derreckla
what were the results?
My ac stopped working on the passenger side rear as well
Thanks
Old Oct 5, 2022 | 06:02 PM
salimshah's Avatar
salimshah
25 Year Member
Thanks
I am missing something here ... What is the connection between the solar sensor and ac for the passenger side + rear?
I think your problem might be with the servo.
Salim
Old Oct 10, 2022 | 05:28 AM
GHBabie's Avatar
GHBabie
Salim
I think they're peeking down the road of possibly having dual climate control, since that's mentioned in the OP as a differentiating factor between variations of solar sensor, per that TSB.
I would think it would be more apparent based on actual buttons if DCC were present (every vehicle I've been in has had separate controls for driver and passenger, and a button to flip between dual and mono(per se?) and that it probably is the servo, a whole separate issue with no bearing on the solar sensor.
Old Oct 20, 2022 | 08:20 AM
GHBabie's Avatar
GHBabie
Originally Posted by rachelgome
Removing a sensor from a node is a two-step process.
... Edit snip ... Salim
Don't let all this confuse you; this is a weird spam account.
Good catch [post deleted and sender notified. Cut and paste are not forgiving ... Thank You. Salim
Old Jun 8, 2023 | 08:03 PM
Xai's Avatar
Xai
10th Gear
Also the
I can’t seem to find the bulletin you mentioned. Can you drop the other two symptoms of a bad solar sensor?
Old Jun 9, 2023 | 06:47 AM
salimshah's Avatar
salimshah
25 Year Member
Before anyone gets too far, please keep in mind the result can be false if the check is done in the garage. Make sure the vehicle is out in the Sun.
Salim
Old Jun 9, 2023 | 07:42 AM
Xai's Avatar
Xai
10th Gear
Default A/c issues
I’m having A/c issues. The compressor doesn’t kick on. I’ve swapped out the climate control, magnetic clutch relay, vacuum checked and filled system at a local shop. I don’t believe there’s a break in wiring anywhere as the compressor turns on and blows cold air when I jump the relay at pins 3 & 5. I’ve also jumped the pressure switch in the front of the car and nothing happens. A/C light is on on the climate control and car has never been in an accident as to possibly having severed wires.
Planning on swapping out the solar sensor. I believe it’s the one that’s connected to the vent believe the windshield. If anyone has any other similar issues please feel free to share.
Update: The DTC 21 Solar sensor disappears if dine out in the sun so back at square one.
Old Jun 9, 2023 | 03:45 PM
Xai's Avatar
Xai
10th Gear
Salim
Yes, if conducted in the garage DTC 21 for solar sensor will appear but won’t if done out in the sun.
Rizico
Feb 27, 2017 12:46 PM
mmatheny
May 19, 2016 07:01 AM
see
Jul 29, 2015 04:21 PM
mrchacon
Jun 26, 2009 05:22 PM
lex bubba
Performance
Mar 7, 2008 09:18 PM
