how 2 check...
Old Jun 26, 2009 | 05:29 AM
mrchacon's Avatar
mrchacon
Default how 2 check...
how do i check the 02 sensor and speed sensor before i go ahead and replace them?
Old Jun 26, 2009 | 08:10 AM
JSM1284's Avatar
JSM1284
Bank 1, 2 Sensor 1
INSPECTION
INSPECT HEATER RESISTANCE OF HEATED OXYGEN SENSORS (Bank 1 Sensor 1, Bank 2 Sensor 1)
(a) Disconnect the oxygen sensor connector.
b) Using an ohmmeter, measure the resistance between the terminals +B and HT.
Resistance: 11-16 ohms at 20°C (68°F)
If the resistance is not as specified, replace the sensor.
Torque: 44 N.m (440 kgf.cm, 31 ft.lbf)
(c) Reconnect the oxygen sensor connector
Bank 1 Sensor 2
INSPECTION
INSPECT HEATER RESISTANCE OF HEATED OXYGEN SENSOR (Bank 1 Sensor 2)
(a) Remove the driver's seat.
(b) Take out the floor carpet.
(c) Disconnect the oxygen sensor connector
(d) Using an ohmmeter, measure the resistance between the terminals +B and HT.
(e) Reconnect the oxygen sensor connector.
(f) Reinstall the floor carpet.
(g) Reinstall the driver's seat
Air-Fuel Ratio Sensor
INSPECTION
INSPECT HEATER RESISTANCE OF A/F SENSORS (Bank 1 Sensor 1, Bank 2 Sensor 1)
(a) Disconnect the A/F sensor connector
(b) Using an ohmmeter, measure the resistance between the terminals +B and HT.
(c) Reconnect the A/F sensor connector.
Old Jun 26, 2009 | 05:22 PM
GS4_Fiend's Avatar
GS4_Fiend
I believe a bad VSS sensor would cause your speedometer needle to oscillate.
S160dre
Aug 11, 2016 06:36 AM
swat1727
Oct 1, 2008 11:50 AM
lex bubba
Performance
Mar 7, 2008 09:18 PM
jacobzking
RX - 1st Gen (1999-2003)
Mar 6, 2008 06:39 AM
