alignment issue?
Old Apr 20, 2016 | 08:00 AM
matts6887's Avatar
matts6887
Default alignment issue?
I have been having a shaking of the steering wheel at highway speeds lately where the steering wheels is shaking and the whole vehicle starts to shake; but also it seems to like to pull to one side a bit. Is this a clear indicator of a alignment issue or is there more to this possibly? Thanks.
Old Apr 20, 2016 | 08:05 AM
salimshah's Avatar
salimshah
25 Year Member
Why would shaking be an alignment issue? Alignment has to do with tracking and tire wear (although tire wear can have other reasons too).
Wheal balancing or suspension are more likely the reason.
You can try swapping wheels to see if that makes a difference.
For suspension, you would most likely need to visit a shop.
Alignment will automatically be part of the final fix after suspension issues have been addressed.
With so many issue related to your vehicle (based on your postings) , I would humbly suggest that you have your vehicle inspected. Then you can evaluate if it is worth fixing one thing at time. You may get a substantial break if you ask one shop to fix them all. You will be surprised that how much money flows out $50~$100 at a time.
Salim
Old Apr 20, 2016 | 08:14 AM
matts6887's Avatar
matts6887
Salim
well; as i said it does like to pull to one side at highway speeds so i always thought thats usually a indicator of needing a alignment. I will have to see about possibly getting a balance done through discount tire which may do it for free; not sure though would have to check on that. as for suspension; I sure as heck hope its not that as thats the last thing I need. Dont need to spend more $; because as it is I had my brake system inspected yesterday and i do need to get the system flushed; and they inspected the drive belts for the water pump and the accessories and apparently both need to be replaced so that $$$. UGH:; the perils of OLD used vehicles. its enough to make me start drinking lol
Old Apr 20, 2016 | 11:03 AM
salimshah's Avatar
salimshah
25 Year Member
What ever you do, make sure you get the suspension checked before you attempt a wheel alignment. You will be paying for the alignment twice if they touch suspension.
Salim
Old Apr 20, 2016 | 06:31 PM
matts6887's Avatar
matts6887
Salim
thanks for the heads up on this salim; i will definitely get the suspension looked at and or repaired if needed before getting a alignment done.
fpb1980
RX - 4th Gen (2016-2022)
Mar 25, 2019 08:41 AM
Danny200t
NX - 1st Gen (2015-2021)
Nov 9, 2018 05:33 PM
hsmac
Sep 29, 2016 05:25 PM
VtotheJ
IS F (2008-2014)
22
Aug 20, 2013 11:51 AM
pdx05470
Dec 7, 2011 08:39 PM
