Will Not Accelerate
Old 09-21-14, 06:11 PM
tap5573
tap5573's Avatar
Default Will Not Accelerate
A friend of mine has a 1999 RX300 with 195,000 miles on it that will not accelerate at all. It starts right up and idles but won't accelerate. Could it be the MAF sensor, TPS or something else?
Old 09-21-14, 06:53 PM
salimshah
salimshah's Avatar
Received 1,019 Likes on 919 Posts
I guess you mean, when (s)he presses the gas pedal, the engine RPMs do not go up in Park.
If yes then check to see if the throttle pulley in the engine turns as the gas pedal is pressed {this can be done with the engine turned off]. '99 RX has throttle connected by cable.
where is the throttle pulley? trace the air path from the filter to the intake. Two cables, one from acc pedal and one from cruise module wrap around a pulley.
Salim
Old 09-21-14, 07:11 PM
salimshah
salimshah's Avatar
Blink its gone and blink its back.
Sorry tap5573 .. I accidentally merged this thread instead of another.
Salim
Old 09-21-14, 08:36 PM
carguy07
carguy07's Avatar
any codes??
Old 09-22-14, 04:45 AM
kalali
kalali's Avatar
What doesn't accelerate? The vehicle or the engine? You put it in D, press gas, engine revs and the car does not move? Or else...
Take the time to be clear about your symptoms if you expect useful help.
Old 12-09-14, 12:16 PM
DewHawk
DewHawk's Avatar
Catalytic converter might be shot. Happened to me once on a chevy.
Old 12-09-14, 05:37 PM
Bobster999
Bobster999's Avatar
Any work been done under the hood lately? bad ground?
'99 SC 400
Performance & Maintenance
05-25-23 09:36 PM
tadiguy
02-19-18 05:30 AM
Dueces
12-01-10 10:18 AM
Luxor
SC- 1st Gen (1992-2000)
14
11-11-10 12:36 PM
IonFeright
03-31-09 01:19 PM
Quick Reply: Will Not Accelerate
