RX300 1999 have P1133 - A/F sensor Bank1 reading
Hi;
Have Lexus RX300 1999. I have only one code reading P1133. I replaced the A/F sensor Bank1 but it still read P1133 . What else could be the issue? Any help please?
Warvet369
Quote;Warvet369; 114--just had a problem with the Air/Fuel Sensor on my 1999 LexusRx300 and had to replace p1153 which cost me for the part $176 plus labor,but,if you go on line you can find it for a lot less. there are some guys on club lexus that have done this kind of work and they can tell you how to do it if you are able.I do know that the A/F Senor looks and installs just like a spark plug with a pi tail to plugin.I did not know this before i joined Club Lexus Forum.
1999 RX300 P1133 what else than O2?
This is quite a bit later, but I'm having the same issue. I had code P1133. replaced the firewall O2 sensor with a Denso twice. Took off Pos battery terminal and took out computer fuse. code came back within 15 miles of driving. What else could this be. Tailpipe has colorless gases, no smoke, engine runs smooth, no misses.
Another thought. Never assume a brand new part is good, especially if you buy it from fleaBay. You could try swapping Bank 1 and Bank 2 AF sensors and see if the codes follow.
I used the correct Denso OEM both times. Didn't use Anti-cease. (I find there is not need to use that if you use liquid wrench after you warm the car for just 5 min, heats just the pipe, but not the part. It comes out without much force at all. prior to this method, massive torque was needed).
Notice my handle, I've changed O2's on several of my vehicles, but this is the first code that is giving me the same code for replacing the O2 with Denso OEM, twice. Must be something else setting it off. Any advice on what else it could be? BTW I've cleaned the Mass air flow sensor as well.
A/F Sensor Circuit Response Malfunction
DTC No.
DTC No.
P1133 (B1S1)
P1153 (B2S1)
DTC Detecting ConditionP1153 (B2S1)
After engine is warmed up, and during vehicle driving at engine
speed 1,400 rpm or more and vehicle speed 60 km/h (38 mph)
or more, if the response characteristic of A/F sensor becomes
deteriorated (2 trip detection logic)
Trouble Area
Trouble Area
- Open or short in A/F sensor circuit
- A/F sensor
- Air induction system
- Fuel pressure
- Injector
- Engine ECU
Thanks Max, went all through the air induction, and wiring, so I'm thinking your top 3 are out. how do I trouble shoot the injectors? I noticed the oil refil lid was split badly, when I took this off while the engine was running, the sound changed, because of the extra air. could this be throwing off the O2 codes?
rmuthiah
12-01-19 11:24 AM
