2001 rx temperature control problem
Old Dec 12, 2013 | 09:31 AM
kenandjoyc's Avatar
kenandjoyc
Default 2001 rx temperature control problem
2001 lexus rx 300 when the climate control temp dial is turned the led display either remains the same or moves slowly. sometimes one must turn the dial 20 times to increase/decrease temp by 1 degree. What can this be? Thanks
Old Dec 12, 2013 | 02:14 PM
mshumack's Avatar
mshumack
Perhaps the "potentiometer" that the **** turns is dirty. Can you spray some contact cleaner in around the ****?
If so make sure the cleaner you use does not harm or stain plastic (test first, or mask off the surrounding area).
Old Dec 12, 2013 | 06:42 PM
salimshah's Avatar
salimshah
25 Year Member
I never had reason to turn the dial more than one turn. Does your turn more than 1 full turn ... you said 20 .. just making sure I read it right.
Salim
guxu
RX - 4th Gen (2016-2022)
Aug 28, 2018 12:05 PM
ISbb
May 19, 2007 12:11 AM
Mousse
Dec 18, 2006 08:03 PM
mvanmeter
Jul 31, 2001 04:05 PM
