Keyless shell case broke
Old Oct 19, 2011 | 04:42 PM
Mut's Avatar
Mut
Default Keyless shell case broke
Hi folks,
Can you guys help me find a place that sells the most affordable shell case for the keyless entry? I strill have the key, I can turn on the engine, remotes buttons work, and everything is fine except it looks like this:
sad face
As you can see, it's cracked but not completely. I almost lost the remote buttons because the shell split in two and the remote fell out. Good thing I noticed.
Thanks!
Old Oct 19, 2011 | 04:51 PM
jagalchi88's Avatar
jagalchi88
here is the link!
Both of my keys broke in the same spot as well
http://www.factorylexusparts.com/ser...Y-SHELL/Detail
Old Oct 19, 2011 | 05:26 PM
iolmaster's Avatar
iolmaster
I bought 3 Lexus blank keys for about $15.00 on ebay. Don't spend $55.00 for one key.
Old Oct 19, 2011 | 06:29 PM
carguy07's Avatar
carguy07
Can you list which seller you used so we know which is a good one?
Old Oct 19, 2011 | 06:38 PM
imherenow's Avatar
imherenow
ya it happend to me too so i superglued it and tape it (just a little)..but that was only temporary..but it did the job just fine..
Old Oct 19, 2011 | 07:47 PM
salimshah's Avatar
salimshah
25 Year Member
The key has three part.
1. Shell half with the key blade molded in.
2. Electronics
3. The other half shell.
I was once in the Lexus parts dept and the associate rummaged through a bin and gave the item#3 for free to a customer ... it was cannibalized from some key. If #3 is broken, check with Lexus parts and if they are as nice as Lexus of Austin, you can have one for free.
Salim
Old Oct 19, 2011 | 08:02 PM
Mut's Avatar
Mut
2. Electronics
Salim
#1 and #2 are both broke and cracked. I don't understand how i'm supposed to replace just #1 if the key blade is molded in. Wouldn't I have to pay a butt load of money to get the new key laser cut?
Old Oct 19, 2011 | 08:48 PM
salimshah's Avatar
salimshah
25 Year Member
I said #3 can be had for free. Cracked #2 is hard for me to visualize. If possible post a pic.
Next cheaper option is to by an uncut key and have it cut by the seller.
If #2 is broken, then search on net for some one selling an old one.
Salim
Old Oct 19, 2011 | 09:12 PM
Mut's Avatar
Mut
Salim
Oops, sorry. I meant broken/cracked #1 and #3. Both shell halves are damaged.
Old Oct 22, 2011 | 04:37 PM
tekillah's Avatar
tekillah
Get a couple of them from here - http://www.dealextreme.com/p/lexus-2...y-casing-16361
They are good and will last you at least a few years if not more. Once you get them, take your old key and this blank to a local locksmith and they should be able to grind the key for you for about $20
Put the old electronics back into this new shell
I had the same issue and it worked beautifully. The key quality is good and this is the cheapest way to replace it.
Old Oct 22, 2011 | 08:03 PM
Dadikins's Avatar
Dadikins
I had the exact same issues with my keys.
Purchased replacements from a guy/company on eBay (Rocket-keys). 2 keys minus the electronics for $40 - CUT & SHIPPED for free. And, you get your choice of colors.
You'll need your 4-figit keycode in order to have him cut it for you. Or he can also work off of a picture (although I'd be less likely to trust that method).
I'm very happy with them!
Boo153
Oct 23, 2018 09:30 PM
Zagman91
Mar 16, 2010 03:32 PM
emolinare
Aug 5, 2007 05:39 AM
