Check engine light
Old Nov 8, 2010 | 10:24 PM
jiciong's Avatar
jiciong
Back again from workshop, this time is going to diagnose my setting with Toyota/Lexus OBDII(Denso), that normally use in SC.
the code also the same as we diagnose with normal OBDII, P1346 VVT Sensor/Camshaft Position Sensor Circuit Range Performance Problem (Bank 1).
So that mechanic help me reset all the setting, now everything alright, wait untill tomorrow, see CEL will active again or not.
Old Jan 4, 2011 | 06:26 PM
IS3_FTW's Avatar
IS3_FTW
Any new updates?
Old Jan 14, 2011 | 01:18 AM
jiciong's Avatar
jiciong
Originally Posted by IS3_FTW
Any new updates?
I sent to others mechanics that is more experience, then problem solved since he open up the cover to check and at the same time change valve cover gaskets.
not related to Sensor. Its jumping teeth, only one teeth of the rear cam.
What Lexmex and Salim said is correct, sensor always the last problem, dun blindly change the sensor.
I already wasted $$ on 2 sensors, one is Camshaft sensor and the other one is VVT sensor, but my VVT sensor still in packaging, never open yet, but cant return to the dealer since he said is electrical parts. So i juz keep it, put at home as antique, bloody hell..
Important is the problem solve, now car run smooth and the RPM is more stable than previous.
Old Jan 14, 2011 | 05:58 PM
IS3_FTW's Avatar
IS3_FTW
^^^Thanks, cus I will be doing the timing belt change, since its time for it to be replaced.
Yup, I had 3 codes pop up on myIS. 2 were o2 sensors and the other was P1346. Thought it wouldve gone away, after changing the o2 sensors, guess not. But now Im just stuck with 1 code
I was gonna change the OCV solenoid to see if that would have fixed it. I dont need to do that now, since you solved the issue of P1346
Thanks again
Ladoo1980
IS - 1st Gen (2001-2005)
Apr 23, 2017 10:28 AM
Bocatrip
May 9, 2014 04:15 PM
edh
22
Oct 7, 2013 04:30 PM
immax01
Sep 3, 2009 04:22 PM
Jellopool
May 1, 2008 01:52 PM
