Just got timing belt done....
Old Jul 20, 2010 | 06:07 PM
jcjr's Avatar
jcjr
Default Just got timing belt done....
Hello,
Just got my T-belt done on my 01 RX at 92K miles ...I was going to wait until 100K but I have some trips coming up and did not want to chance it...
Toyota dealer...$325 plus tax...
Water pump, idler, pulleys all looked great according to the tech....I had given clearance to change any of the above if needed.....They said only belt needed!!!
Old Jul 20, 2010 | 08:29 PM
99rx's Avatar
99rx
Still should have done it for a preventative measure. You never really can tell how a water pump looks. Just hope that it doesn't go after you had it all apart. But just my 2 cents.
Old Jul 20, 2010 | 08:52 PM
trhs75's Avatar
trhs75
Wow -- that's a pretty reasonable price, isn't it?
Old Jul 20, 2010 | 11:23 PM
salimshah's Avatar
salimshah
25 Year Member
More and more members are feeling that at 90k water pump replacement is preemptive. In any case it should be examined. If any one plans of replacing it, my recommendation will be to buy OEM.
Salim
Old Jul 20, 2010 | 11:41 PM
code58's Avatar
code58
Salim
The last is not negotiable (in my book anyway). The 1st statement is true, up to the comfort and wallet of the owner. I wouldn't argue with anyone who did have it done, though I don't personally think it's necessary at all. Truly an engineering work of art. If Toyota/Lexus didn't recommend them at 90k mi, but rather replace when bad as so many have done over the years in other cars, they would hardly EVER sell one. At around 127-130k mi. when I replaced my DIL's while looking for the source of a 2-5 second squeal at start, I was amazed to find upon cutting it apart with a die grinder cut-off blade that it was absolutely like new in every respect.
Old Jul 21, 2010 | 11:44 AM
maxSteel's Avatar
maxSteel
Just checked my bill from Toyota for my 99 rx300 which had 198k at that time
They did the following
replace timing belt and drive belts: $545
replace cam and crank seals: $179
replace water pump: $265
Grand total: $989
Old Jul 21, 2010 | 11:57 AM
ralfyb's Avatar
ralfyb
$545 NJ v $325 AZ Am I missing something I thought all dealer prices are the same for the same job just the tax changes My FL & NY dealer both gave me the same price for a hitch
Old Jul 21, 2010 | 02:04 PM
jcjr's Avatar
jcjr
The RX is currently in Washington State....Part was $55...Labor $268.....
I did not push to have the rest done as they said they would not recommend it....The water pumps appear to be very reliable according to them...
If i need the water pump done the cost would not be vey high...
Old Jul 21, 2010 | 02:05 PM
jcjr's Avatar
jcjr
Also,
I had the the drive belts done already.....
I can change the water pump at 180K miles with the next timing belt!!!
Old Sep 1, 2010 | 05:41 AM
shawnst's Avatar
shawnst
Default where is timing belt
I also had timing belt and drive belts done yesterday .. just wondering, where is timing belt? can you see it without removing any cover/parts?
I saw there are two belts at the left (passenger side) bottom. I am guessing that's not timing belt? The shop I went to charged 4 hours of labor to do it.
Thanks.
Old Sep 1, 2010 | 10:09 AM
salimshah's Avatar
salimshah
25 Year Member
The engine is transverse mounted, that makes the front of the engine on the side of the front passenger wheel. Timing belt is not exposed and is hidden behind the cover. [It is the front most portion of the engine block] The arrangement is "Y" shaped as it is a V6 engine.
Salim
Old Sep 1, 2010 | 01:29 PM
genijet's Avatar
genijet
Smile Timming belt
Originally Posted by jcjr
Hello,
I had the same problem but i deceided to go all the way. Belt, water pump, spark plugs, Syn oil change. Carl
Old Sep 29, 2010 | 12:19 PM
rx300mm's Avatar
rx300mm
To understand how T-Belt and water pump is replaced I found videos on youtube, this guys explains it well. Part 1 & 2
http://www.youtube.com/watch?v=DI60MOkf168
http://www.youtube.com/watch?v=7D_8u...eature=channel
Old Sep 29, 2010 | 05:28 PM
Lexmex's Avatar
Lexmex
That's extremely well done. I am going to copy this post and throw it in the DIY section.
KimO
Maintenance
17
May 1, 2019 06:38 PM
imherenow
May 20, 2011 03:43 PM
iman61701
Oct 26, 2010 03:42 PM
auto228 V8
Performance
Jun 8, 2006 09:51 PM
