Loud buzzing noise
Old Mar 1, 2009 | 12:59 AM
5t341th's Avatar
5t341th
Default Loud buzzing noise
hi guys. im trying to find out some problems with my mom's 01 RX300.
first of all, there is a loud buzzing noise coming from the front passenger side. i believe its under the dash somewhere. it randomly sounds and goes off after a while. i thought at first that it was the cd changer but it was not. could it be the blower motor in anyway? any ideas?
another thing, the passenger window doesnt go up when i want it to. once i roll the windows down and try to make it go back up, it does nothing. even if i control it using the driverside switches, the same problem occurs. after i keep pulling the window switch for a while, it will decide to go up. what could be the problem for this? i think it could be a loose wire/harness.
theres some other problems too (driver lock doesnt work, antenna doesnt retract) but i found out the causes for them using search already.
thanks all for any help
Old Mar 1, 2009 | 08:07 AM
salimshah's Avatar
salimshah
25 Year Member
Buzzing noise: [Total speculation on my part]
Search for "air servo" ... if the sound source is between gear selector and glove box.
Window: Depending on your model, it could be the pinch protection. You can reprogram it by holding the switch up and let the window travel all the way up. Or it could be the motor which needs some attention. Search the post by Lexmex on how to lube it.
Door lock actuator and whip antenna replacement ... you are already on that trail.
Salim
Old Mar 1, 2009 | 05:21 PM
5t341th's Avatar
5t341th
thanks for the suggestion. the buzzing noise comes from directly underneath the dash on the passenger side.
i've read a few posts and notice a few people say to disconnect the battery and reattach. it will fix it
gs3andahaf
Mar 16, 2013 10:29 AM
BURRLiN
May 28, 2012 11:16 PM
hcleu
Mar 30, 2008 02:46 PM
acl15
Nov 1, 2006 08:24 PM
garbage85
May 20, 2006 10:22 AM
