RX 300 Engine Differences
Old Feb 27, 2009 | 11:27 AM
rkirchn's Avatar
rkirchn
Default RX 300 Engine Differences
I have an all wheel drive 1999 RX 300 with a bad rod bearing. While shopping for a used engine I have noticed that people list the all wheel drive and two wheel drive motors seperatly. Is there an actual difference between the two engines, or is this a ploy to charge more.
Old Feb 27, 2009 | 12:49 PM
lexus114's Avatar
lexus114
this may be one for lexmex.as far as i know,their is only a difference with the trans.not the motor.
Old Feb 27, 2009 | 12:56 PM
Lexmex's Avatar
Lexmex
There is, but I don't think with respect to the broken piece in question there is a difference in that particular part. I didn't think so but I also just checked in my service manual and didn't see any as they distinguish between FWD and AWD when it happens on such parts. What came to mind immediately was the location of the engine drain plugs (they are in different locations on the FWD and AWD). Of course the transmissions are also different, too.
Old Feb 27, 2009 | 12:58 PM
Lexmex's Avatar
Lexmex
I was also just studying this and didn't see a difference per se on the part, http://www.trademotion.com/partlocat...layCatalogid=0
Old Feb 27, 2009 | 01:14 PM
lexus114's Avatar
lexus114
are you sure they werent referring to vvt-i,and non vvt?
Old Feb 27, 2009 | 02:22 PM
Lexmex's Avatar
Lexmex
They're vvt-i, but there are subtle differences in the engines. I am not sure on all of them but I know there are between the AWD and FWD models.
Old Feb 28, 2009 | 01:25 AM
code58's Avatar
code58
I think what the poster was asking essentially was if he found a good used 2WD would there be any differences that were of any consequences as far as using it in his 4WD (or AWD). Didn't want to buy it and get caught like Thomas's neighbor did with the Highlander.
Old Feb 28, 2009 | 07:54 AM
Lexmex's Avatar
Lexmex
I don't think he needs a new engine, he just needs to replace the part in question, that's certainly a lot less than getting a new engine and taking it out.
Old Mar 1, 2009 | 12:37 AM
code58's Avatar
code58
I'm not disagreeing with that, I was just pointing out the question that he asked. The problem with replacing the rod bearing (plus maybe the rod, but not a huge chance that would be bad) is that by the time the rod bearing has gone out it would be unusual for it not to have damaged the journal. Then it would still require removing the engine to deal with having the crank re-ground, if it could be. I can't honestly remember the time that I have seen a rod bearing go out without any damage to the journal.
Old Mar 1, 2009 | 07:23 PM
thomas1's Avatar
thomas1
Be very careful, my neighbor got burned, because there were not mounting holes for one of the motor mounts on the engine. That Is something I would like to know, do the FWD engines have a motor mount on the crankshaft end of the engine on the subframe?
rx2000
Feb 3, 2010 03:53 PM
toyo
Oct 30, 2003 04:39 PM
habibnazir
12
May 27, 2002 09:25 AM
