alignment?
Old Jun 9, 2008 | 11:47 AM
m1tk4's Avatar
m1tk4
Originally Posted by mikey00
If I don't have abnormal tire wear or any pulling, I stay away from an alignment. You run the risk of them taking your perfect alignment and knocking it out a little. Even the best front end guys are paid by volume and are in a hurry.
The last alignment I did was on my Honda (dealer), and they have shown me the printout with the measurements BEFORE doing the alignment. It saved me some $$$ since the rear axle was actually fine.
I would imagine a good shop could do the same and let you know if you actually need an alignment or not.
Old Jun 9, 2008 | 01:42 PM
Lexmex's Avatar
Lexmex
The Hunter machine actually gives a printout of the before and after. That's the only one I have found that can do the true 4 wheel alignment for AWD.
Old Jun 9, 2008 | 02:07 PM
mikey00's Avatar
mikey00
The purpose of the printout is to give you, the customer a warm fuzzy feeling and I guess it is working. The printout assumes the operator has done everything correctly. There is still room for operator error.
Old Jun 9, 2008 | 03:03 PM
archangels's Avatar
archangels
wait was that a demo of auto tranny fluid if not changed on time? the kool thing i tested my alignment drives straight and smooth if it is off it would be steering wheel but only by 2mm or it can be in my head it was close to straight, i looked at my tires no unven balding, (got lucky) as i am broke once i buy 4 new tires and oil and tranny oil drain and fill maintenece
Old Jun 9, 2008 | 09:04 PM
Nad1370's Avatar
Nad1370
As the majority stated..
New tires = Alignment.
Old Jun 10, 2008 | 01:29 AM
salimshah's Avatar
salimshah
25 Year Member
A small group is also saying .. if it is not broken, dont fix it.
Salim
Old Jun 10, 2008 | 05:01 AM
Lexmex's Avatar
Lexmex
Two more important things to take care of are first rotation (and second balance). I saw so many times back in Mexico where the front left tire was a bit more worn (especially on the corners), because the weight of the driver and to a lesser extent the engine combined with no tire rotation caused this tire in particular to be worn down and the right side front tire to a lesser extent to be worn compared to the rear tires.
Old Jun 10, 2008 | 07:22 AM
thomas1's Avatar
thomas1
I agree, rotation and re-balance is important. those free rotations and balances at many places are worth a lot.
Old Jun 10, 2008 | 10:33 AM
archangels's Avatar
archangels
so everytime you do tire rotation you do tire balance also same time everytime? companies allow that thanks buddy... also how often you do a tire rotation? thanks
GenuineKid
IS F (2008-2014)
Apr 22, 2012 04:55 PM
n8236
Suspension and Brakes
Mar 7, 2012 09:33 AM
niteflite
Mar 26, 2010 08:07 PM
runningox
Feb 21, 2009 11:27 AM
Jayson
Jun 27, 2007 05:49 PM
