help, rotors......
Old Jan 25, 2007 | 10:35 PM
p y's Avatar
p y
Default help, rotors......
alright well i am new to the forum but i had a question my left side front and rear rotors came off with no problems. now the right side will not move at all! i sprayd wd40 around the hub and where it meets the rotors. what could i do to break them loose?!
Old Jan 25, 2007 | 10:41 PM
cobravap's Avatar
cobravap
Just wait...overnight with the wd40 and pull hard. I dont remember the name of the other spray you can use, but im sure someone else can shine in on that.
Old Jan 25, 2007 | 11:28 PM
salimshah's Avatar
salimshah
25 Year Member
Another producr is liquid wrench. All penetrating oils leave a residue, so a through clean up would be required on reassembly. Also protect the pads from the oil.
I have always had better luck with the spray, followed by jarring blow with 5lb hammer and then an overnight soak with a wet rag covering the joint. You may prefer to use rubber mallet or piece of wood to prevent damage to rotor surface,
Salim
Old Oct 12, 2008 | 02:49 PM
genijet's Avatar
genijet
Default Dead Battery
After leaving my car at night, i went the next morning to start the car and it would not start. So I put the battery charger on,and after 1 hr it started. I replaced the battery any way. what would my problem. Its not the battery i had i checked. Carl
Old Oct 12, 2008 | 03:45 PM
salimshah's Avatar
salimshah
25 Year Member
By accident it seems to be the wrong thread.
Salim
kphu
GX - 1st Gen (2003-2009)
26
Oct 12, 2023 05:39 PM
gsean400
Apr 22, 2016 02:50 PM
ISFPOWER
IS F (2008-2014)
Sep 7, 2014 10:00 PM
anesthesia
18
Mar 27, 2013 05:41 AM
jbl-1985
Aug 13, 2010 01:36 PM
