check engine code PO 440 PO 446
Nothing beats the process of smoke testing the vacuum issues. The hose run every where and I can understand the easy target the gas cap. The cost of equipment to run the test vs paying a shop is for you to decide. I am assuming all valves are working right and there is a vacuum leak
Salim
Salim
The quick things to check are the gas cap and the hose connected to the airbox. After that there's no quick solution. This thread and other like it give you test procedures for the canister itself and the hoses and VSV's. There is a sticker under the hood with a vacuum lines and switches diagram. A vacuum tester to test hoses and VSV's isn't expensive
charley240
35
Jul 18, 2024 05:53 PM
imjohnphan
Jan 20, 2022 11:58 AM
