97 ES300 Check Engine Light
I took my car to meineke and had the codes pulled. It came out with
code P0441 EVAP. Can anyone help how to fix this problem? Thanks!
Possible issues:
Open or short in VSV circuit for EVAP
VSV for EVAP
Open or short in vapor pressure sensor circuit
Vapor pressure sensor
Open or short in VSV circuit for vapor pressure sensor
VSV for vapor pressure sensor
Vacuum hose cracked, holed, blocked, damaged or disconnected
Charcoal canister cracked, holed or damaged
What tripped the code:
The pressure int he charcoal canister does not drop during purge control
-or-
During purge cut-off, the pressure in the charcoal canister is very low compared with atmospheric pressure
Check your vacuum lines. If it isn't a problem with those, I think your VSV valve would be the most likely cause.
Husuton2
Jul 28, 2008 11:20 AM
