Fuel Filter
Old Apr 29, 2006 | 09:31 AM
ravengotu's Avatar
ravengotu
Default Fuel Filter
My 2000 RX, Just started hesitataing and is rough starting off the line at light...could this be a filter, No enegine light,,,and after a few corners it seem to have gone back to normal...bad fuel maybe..please any ideas..........
Old Apr 29, 2006 | 03:36 PM
Lexmex's Avatar
Lexmex
This time I am going to recommend to wait until after your next fillup and I would choose a different gas station just to test.
Old Apr 29, 2006 | 08:27 PM
ravengotu's Avatar
ravengotu
Default thanks
Yeah i am going to filler up tomm....no more costco gas...for sure
Old Apr 30, 2006 | 08:48 PM
HarrierAWD's Avatar
HarrierAWD
I use CostCo gas occasionally and it runs fine.
Old Apr 30, 2006 | 09:01 PM
TunedRX300's Avatar
TunedRX300
Costco actually periodically check fuel filter at the bump so your fuel filter does not have to work as hard. WSJ reports Costco gas came from Shell, Chevron, or BP, just minus the additives.
Old May 1, 2006 | 06:13 AM
Lexmex's Avatar
Lexmex
I have said it many times that the gas I used in Mexico is full of impurities, even when using the Premium 92 Octane. Not only the sulfur, but just whatever else is lurking in those tanks. American gasoline so far superior to what I use here.
Old May 1, 2006 | 09:12 PM
HarrierAWD's Avatar
HarrierAWD
Actually, CostCo gas also contains cleaning additives as required by local law. You could get the Shell, Chevron, or BP additives at CostCo. It's just like a box of chocolate, you never know what you gonna get.
While it is true that each oil company has its own blend of additives, they all work very well.
Old May 1, 2006 | 11:15 PM
Lexmex's Avatar
Lexmex
He could have gotten the bottom of the tank gas. When I see the tanker truck at the station, I move on to the next.
Old May 6, 2006 | 06:49 AM
ravengotu's Avatar
ravengotu
Default Could be all the above...
I should not blame the gas........its that at 3.40 a gallon everyone is using so much here.....and the problem continues....but when my check engine light comes on...all is fine....very weird.i need and OBD scanner...any good ones around
Old May 6, 2006 | 08:29 AM
Lexmex's Avatar
Lexmex
Actually, premium in Mexico is close to $3 USD unless you buy in the border zone where it is cheaper to stay competitive with the U.S.
However, I would rather pay $3.40 and fill up on U.S. gas than fill up on the garbage down here.
Thank nationalized oil.
Old May 6, 2006 | 12:13 PM
TunedRX300's Avatar
TunedRX300
The next thing I check is IACV, check out another thread. Could be clogged by carbon buildup and not enough air for the engine at idle.
https://www.clublexus.com/forums/sho...d.php?t=215190
Old May 7, 2006 | 07:18 AM
ravengotu's Avatar
ravengotu
Unhappy Very strange
I noticed my idle is like 650 vise the 750...hesitation is horrible...i took to auto zone and they said it read code (sorry dont remember)... vacuum leak...but when engine light comes on it runs perfect..... might be time for a trip to toyo service....any thoughts ....It would be a real help
Old May 7, 2006 | 07:32 AM
Lexmex's Avatar
Lexmex
Actually, the exact code would be the useful one, since then I can go to the RX service manual.
Sometimes, when the weather gets hot and humid like it is now, my idle also creeps a tad below 750 RPM.
With a vacuum leak, we are most likely talking about a hose being disconnected or there is a hole in one of them. My uncle and I use the old trick of spraying water on all of the air hoses to find any leak and see if bubbles show up.
When the CEL or engine light comes on, from what I have read in the service manual, this forces the ECU into some type of default mode and all will appear to run normal.
mbbf
Feb 4, 2013 04:36 PM
shikbas
May 28, 2009 07:29 AM
Tymboo
Aug 30, 2007 10:20 PM
last993
Nov 30, 2003 05:16 PM
fallabel
Jul 8, 2003 09:12 PM
