Check Engine Light 99RX 300 Help!
Old Oct 13, 2005 | 07:20 PM
Bjt's Avatar
Bjt
Default RX300 check engine light
The problem was intermittent for a couple of months. The light is on all the time now (over a month). This is after I upgraded the gas from 87 to 89. Dealer diagnose problem as air flow sensor I believe. Told me it would cost around $300 or more. The light isn't blinking and I haven't notice any strange sounds. Do I have options other that forking out over $300. Feedback welcomed.
BJ
Old Oct 18, 2005 | 01:31 PM
mmahamm's Avatar
mmahamm
BJ
Buy a toyota or aftermarket air flow sensor and have an independent mechanic do the work. On Rockauto.com a Mass Airflow Sensor is $69 or $79, depending on which one you buy. If you put it in yourself, your total cost is less than $100. An independent garage shouldn't need mor than an hour labor to do it, so it would certainly be less than $200.
Onitlex96
Aug 29, 2011 03:49 PM
archangels
16
Apr 12, 2008 12:25 AM
sdbeal
Mar 29, 2008 08:13 AM
33333333
Maintenance
Feb 12, 2005 05:05 PM
