Whining sound
I recently purchased a 2000 RX300 with 62,000 miles on it. The interior cabin is very quiet so I can hear this high pitch whining sound during acceleration and while maintaining constant speed. My wife says it wind noise but I say its either from the engine or the transmission. Anyone have a similar experience, know whether its a Lexus characteristic, or know how I can eliminate this irritating sound?
Also, how come when the headlights are on and I turn off the engine, remove the keys and exit the vehicle, the headlights remain on? My Volvo's headlights turn off immediately when the engine is turned off and the Mercedes headlights stay on for 30 seconds before turning off.
I had a whining sound at specific mph when coasting. They (dealer) tried changing many items--bearings, differentials, etc. and it didn't help, but the whining sound changed at a diff. mph when coasting. Then it would happen only in the AM. They kept it overninght and tested it. It ended up being the transmission which they replaced. There was about 64,000 miles on the odometer. Good luck.
The light off delay time may be programmed by the cbest ... check dealership and t can be doen when you atke the RX for service.
Till that time use the remote to lock the vehicle .. I think you need to do it twice.
There are too many sources of noise. Speed (independant of acc) will cause wind noise. Noise based on rpm is usually from engine/trnasmission/wheels. Then there can be a combination of engine-rpm, transmission-in-x-gear & wheel. If you can only isoalte and say that the noise is only under accellaration .. I would check the air filter.
Salim
Salim
The automatic-off is on a delay, like the Mercedes. As Salim said, the amount of time is adjustable by a dealer. He's also correct that clicking the "Lock" button on the remote twice will shut off the headlights immediately.
Another notorious source of noise on the RX300 is the roof rack crossbars. If you've got them, they can make wind noise depending on their position. You can ask the dealer to look up the instructions for installation of the crossbar accessory kit; the instructions have measurements for locating the bars in an optimum position to decrease noise. The tie-down loops can also cause the same problem, depending on which way they're facing. Again, consult those instructions.
Since the vehicle did not come with a roof rack, the sound is definitely not from the rooftop. The high pitch whining is related to engine and transmission acceleration. I'm thinking of flushing out the transmission fluid and having my mechanic drive and hear it for himself.
If your still in warranty, take it to the dealer and have the transmission addressed. If not, there is a debate as to whether flush or several drain and fills over a thousand miles. With your milage, I hope your fluid has been changed several times.... But, read this forum on transmission flush or drain and fills... Toyota dealers may do the task a little cheaper, using the Toyota Type-IV fluid.
My 2000 RX300 with about 64,000 miles was having minor starting problems during the recent cold weather so I replaced the orginal battery with a Sears Diehard. After replacing the battery and driving on the expressway, I immediately noticed that the constant high pitch whining sound I wrote about could barely be heard. While changing the battery, I bumped the air filter box several times, the battery clamp bracket was tougher to reinstall because the new battery is a little thicker, and the cables were reinstalled in the same angle. Something eliminated that irritating high whining sound. Its definitely not a transmission or engine issue. My guess is that the battery bracket was originally positioned with a little gap, which created the high pitch sound or perhaps the air filter box got into its proper seating position.
Originally Posted by katzjamr
bobk528 what color is your transmission fluid,
Salim
Salim
Salim
Salim
uh,have another one for me their buddy!!!.....
Mmmmmm,BEEEEEEER
all very good ideas but the first thing i thought of was an issue we ran into back in high school when we would install aftermarket radios, sometimes we wouldnt ground something properly and we would get that exact same wiiiiiiiiiii noise and it would go with accelleration, not saying that a stereo is your issue but maybe something isnt grounded right, just a thought
