Whining sound
Old Aug 11, 2009 | 12:49 PM
lexus114's Avatar
lexus114
Originally Posted by UNOHOO
all very good ideas but the first thing i thought of was an issue we ran into back in high school when we would install aftermarket radios, sometimes we wouldnt ground something properly and we would get that exact same wiiiiiiiiiii noise and it would go with accelleration, not saying that a stereo is your issue but maybe something isnt grounded right, just a thought
Yeah womp had to fix that problem on his 1972 Dodge Dart Swinger....
Old Aug 12, 2009 | 05:14 PM
frankjames's Avatar
frankjames
Originally Posted by Mark2008
We began noticing an RPM-dependent high pitch whining noise from beneath the engine, seemingly associated (we hope) with the mesh covering on the exhaust pipe, just downstream from the exhaust manifold. With the engine running at idle in Park, the noise seems to be positional relative to the right side (engine side) of the mesh covering, which I assume is a flex joint. What we hope is that the noise is not associated with engine gel/sludge and that then noise is an engine part screaming for lubrication. Definitely, the noise is loudest beneath the engine, at idle, and increases in pitch with RPM. We do not observe any smoke exiting from the exhaust pipe, nor any check engine light and the temp gauge is at normal, even on a 100F day. I am writing to the Lexus dealer in Eugene to follow this thread.
When my engine failed no extra noise. As for smoke or whatever, your exhaust will have an excessive black build-up on the inside edges if it's burning oil and you will notice DEFINATE oil consumption. These are some of the symptoms of sludge. In 2200 miles, my engine oil went from brand new and full to below the level of reading on the dipstick and black. What happened to me is the oil pick up was plugged with sludge and couldn't properly lubricate so it threw the rod furthest from the oil pick up. Flex pipe is common issue,easy to inspect and see if that is the problem......
tpeene
Jun 16, 2024 10:07 AM
Evant
RX - 3rd Gen (2010-2015)
57
Jun 9, 2024 07:57 AM
yuyangbit
Oct 8, 2016 08:59 PM
ml30306
Jul 22, 2011 08:42 PM
TheCat1
May 22, 2011 07:23 AM
