Rear Window Noise
Old Feb 6, 2005 | 01:10 PM
lexdog's Avatar
lexdog
Unhappy Rear Window Noise
I own a 2001 RX300 When only one rear window is down a loud reverbrating noise pulses through out the SUV. It vibrates my ears and is extremely un-nerving. If I roll down another window or open the sun roof the noise goes away. Has anybody else encountered this problem. If so how did you resolve it ?
Old Feb 6, 2005 | 02:17 PM
spwolf's Avatar
spwolf
wind turbolence? :-). Everyone that opens one window at high speeds encounters this "problem", in any car... thats why you have to open two of your windows, if you want to avoid the turbolence...
Old Feb 6, 2005 | 07:00 PM
steevr's Avatar
steevr
It's also another reason on the RX300's that went you press the "one touch open" on the sunroof, the sunroof doesn't quite open all the way. If you were to press open a second time, the sunroof would open another inch or two, however, you get that same "resonating" sound with the sunroof open all the way.
Old Feb 6, 2005 | 08:49 PM
salimshah's Avatar
salimshah
25 Year Member
You will find plenty of posts on this issue.
You have already discovered the solution as well.
Salim
Old Feb 6, 2005 | 08:59 PM
Lil4X's Avatar
Lil4X
Out of Warranty
Post The E-flat RX redux
The “helicopter” noise you describe is common to modern vehicles that have had extensive wind tunnel development resulting in laminar airflow over major surfaces. When you open one window or the moonroof to just the right aperture, you will create a chamber resonance similar to that produced in a flute, but at a very low frequency.
We’ve discussed this effect many times in the last few years – for a review of all the posts, try an advanced search (under the search button at the top of this thread) on "helicopter" for all articles on the RX forums. You'll get about eight threads describing the phenomenon in detail, its causes and cures.
Old Feb 11, 2005 | 08:35 AM
HarrierAWD's Avatar
HarrierAWD
All RX300 have that issue. You'll also get the buffet noise from the moonroof at about 45 mph.
Turn the fan on to medium or higher setting, or open another window or moonroof.
Old Feb 11, 2005 | 03:31 PM
NeverSatisfied's Avatar
NeverSatisfied
My 330's moonroof does it between 30-40mph, so, I just drive faster!
rvgraham
Feb 21, 2018 06:05 PM
karolgt
Sep 27, 2014 05:58 AM
isam250
Nov 28, 2007 12:11 PM
yaro1
GX - 1st Gen (2003-2009)
May 6, 2005 09:27 AM
tomrx330
Nov 16, 2004 12:06 AM
