Clunking Sound?
Old Oct 12, 2004 | 12:06 PM
Philly#1 Lex's Avatar
Philly#1 Lex
Question Clunking Sound?
We've had this problem for a couple of months now and have been wondering if anyone else has been experiencing it. Everytime I go over a bump i hear a clunk from the rear of the car? Like something is loose or something? Does anyone else experience this? It's a 2001 Rex with 50,XXX miles?
Philly
Old Oct 12, 2004 | 01:28 PM
mooretorque's Avatar
mooretorque
Talking
Some first gen RXs had problems with strut tower mounts (not dangerous, but can make suspension sound as if it will fall out) both front and rear though most prevalent in 99. Of course, there can be other things loose back there. Plus a 2001 may be close to needing new shocks...............
Old Oct 12, 2004 | 03:01 PM
Philly#1 Lex
Where can I get replacements for a good price? It doesnt look like its saging in the back to need nnew shocks but I will recheck. Is the strut tower mounts a easy fix or a dealer job?
Philly
Old Oct 12, 2004 | 08:13 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
If you are not mechanically inclined, leave it to a pro. Also it's best to do a front wheel alignment after an operation like this.
Old Oct 12, 2004 | 10:27 PM
HarrierAWD's Avatar
HarrierAWD
Remove everything from the cargo area and secure the spare tire and the jack. Go over the same bump again.
Old Oct 13, 2004 | 04:48 AM
Lexmex's Avatar
Lexmex
I had this problem on my 99. True Flipside, you can leave it to a pro, but being south of the border my 'independent Lexus mechanic" and I worked on the back, tightened the screws replaced the rubber lower supports and sprayed some WD-40 in there, nothing.
Now, I did have that clunk on the front left side a few years ago, and there was a broken shock, but this was more of a clanging than a clunk.
Old Oct 13, 2004 | 05:56 AM
Rx900's Avatar
Rx900
hmmm, i don't remember having a clunk sound in my 00 Rx! Probably becuz i am very careful not to run it over bumps and pot holes!
Old Oct 13, 2004 | 07:39 AM
mooretorque
Talking
Doesn't have to sag for shocks to have gone "flaccid". The springs support the (sprung) weight of the vehicle; shocks are there so that you don't pogo up and down at the spring's harmonic frequency. Without a spring compressor, this is not a DIY job, in my opinion. (Plus, in my case, I don't have the time to spend even if I had all the proper tools.)[
QUOTE]Probably becuz i am very careful not to run it over bumps and pot holes![/QUOTE] So am I and so is SHE; the failures of the strut tower mounts weren't due to suspension abuse. There was a TSB issued.
SerasLibre
Jul 26, 2014 06:01 PM
ptownTSI
GS - 1st Gen (1993-1997)
Jan 20, 2007 09:52 PM
92 SC400
Nov 9, 2006 07:15 PM
SeattleGS400
Aug 4, 2006 01:17 PM
snowwhite
Maintenance
Jan 1, 2004 03:35 PM
