Central locking problem
Old Feb 15, 2026 | 11:01 PM
jonas's RX's Avatar
jonas's RX
And to add even more color to this thread
I was curious and asked my local Lexus dealer the cost for replacement of the aculator and here it is. $1,000 per door with Lexus
2001 RX:
Driver door actuator $573.58
Passenger rear door actuator $555.58
Labor is $449.88 each
Old Feb 16, 2026 | 07:17 AM
salimshah's Avatar
salimshah
25 Year Member
Adding a bit of detail FWIW:
All 4 doors have a different part number.
Salim
Old Feb 16, 2026 | 09:17 AM
OneLegCraig's Avatar
OneLegCraig
I ordered and installed these. The only issue i have is that very intermittently i have to reprogram the remote and then unlock/lock the passenger door manually to get the remote to start working again. Its worth the $1,975.00 savings.
I replaced all four so I guess the savings is $3,975.00 😁
https://a.co/d/0bxlTesz
Old Feb 18, 2026 | 05:22 AM
maxSteel's Avatar
maxSteel
Well it's my turn now. Driver side rear is unlocking but not locking. The door manual lever is only moving about half way. It's cold here so maybe that is a factor.
What's the issue you mentioned about "reprogramming the remote"? Why does the replacement actuator require this?
Old Feb 18, 2026 | 05:25 AM
OneLegCraig
I dont know what happens but programming it is extremely easy so i never worried about looking into it much because it happens only about once or twice a year. Its a communication issue between the aftermarket part and the vehicle i assume.
Old Feb 18, 2026 | 09:19 AM
salimshah's Avatar
salimshah
25 Year Member
Never be in a hurry to re-program. If not done right you will compound your problems.
There is no smarts [other then mechanical] in the actuator. If the front doors inside electronic button can NOT operate the locks [lock/unlock] there is no need to look further back [remote sender/receiver/programming] etc.
There can be mechanical binding and difference in force needed to lock vs unlock.
Salim
Old Feb 18, 2026 | 09:35 AM
OneLegCraig
Salim
Good to know but it seems to be working fine and I didn't/don't need to spend 4k to repair it. I have never in 2 decades experience ran into reprogramming a remote hurt anything. Sounds a bit overly cautious to me.
Old Feb 19, 2026 | 08:00 AM
salimshah's Avatar
salimshah
25 Year Member
I understand and respect your view point as it is based on your 20+yrs of experience, and where I stand 100% with you is ...if there is an issue in programming, your approach WILL get you the right solution quicker. Granted my process is more methodical and slow.
What we are is based on what we have learnt over life.
Salim
Speedin
Sep 19, 2022 03:12 AM
Acky123
Jul 22, 2016 07:41 PM
fongph
Dec 31, 2014 10:46 AM
Andrewgs
May 20, 2013 02:39 PM
JustinCash
Jul 9, 2004 04:04 PM
