Backup lights
Old Nov 13, 2025 | 04:23 PM
HadYourPhil's Avatar
HadYourPhil
Default Backup lights
I am trying to put LED bulbs in my backup lights but I can't figure out how to get to the bulbs in the fendèrs My manual-on-a-cd is of no help.
Maybe we need a "sticky" on bulb replacement?
Old Nov 14, 2025 | 10:04 AM
HadYourPhil
Here is the left side of the back.0
[img alt="Left side.
"]https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x2000/20251114_115634_968787356e34acfc0d48777b0a5a30e1c68cd754.jpg[/img]
Any ideas?
Old Nov 15, 2025 | 03:17 PM
maxSteel's Avatar
maxSteel
Isn't this it:
Old Nov 15, 2025 | 05:43 PM
HadYourPhil
No, the ones I can't figure out are the ones in the car body. The tailgate bulbs are easy. Thanks anyway.
Old Nov 15, 2025 | 06:51 PM
maxSteel's Avatar
maxSteel
Your post says: "I am trying to put LED bulbs in my backup lights but I can't figure out how to get to the bulbs in the fendèrs My manual-on-a-cd is of no help."
So it's confusing as to if you were asking about the backup lights or the front or rear side marker lights. Side markers are accessed through the wheel well. See: https://www.clublexus.com/forums/rx-...ml#post7035497
Old Nov 16, 2025 | 06:26 AM
HadYourPhil
I'm not sure what the confusion is.
The rear of the car has, arguably, four tail lights, two in the lift gate and two on the rear corners/fenders. The ones in the lift gate are easy to get to but the other two are a mystery to me.I I'm probably overlooking something obvious.
And if that wasn't enough for me to deal with, I am unable to locate the PCV valve.
My car is a 2001 RX300, BTW.
Old Nov 16, 2025 | 11:57 AM
maxSteel's Avatar
maxSteel
The confusion is that this thread is titled "backup lights", which usually refers to the white lights that turn on when you are in reverse. You also referred to rear corners/fenders.
The drivers-side rear of the car has 5 bulbs:
  • 1 backup (reverse) light in the liftgate lens
  • 2 combination tail light/brake light. One in the corner lens, one in the liftgate lens
  • 1 turn signal in the corner lens
  • 1 side marker in the bumper
Side marker bulbs: https://www.clublexus.com/forums/rx-...ml#post7035497
Rear corner bulbs: https://www.carcarekiosk.com/video/2...hts/tail_light
Liftgate bulbs:
PCV valve in the rear valve cover on the passenger side
Old Nov 17, 2025 | 12:02 AM
salimshah's Avatar
salimshah
25 Year Member
Also PCV has changed over the model years. The earlier had a push-in grommet style and the later with the threads. If you have the push in type, remember to purchase the grommet as the old one will not be in a re-usable condition and most likely will need to eb cut/ripped to extricate.
Salim
Old Nov 17, 2025 | 05:22 PM
HadYourPhil
The screws that hold the tail light assemblies are very well hidden! I had to really look hard to see where the small covers over the screws are. Thanks for the YouTube link!
I replaced the incandescent bulbs with (expensive) LED replacements. Major difference! Now I won't back over the cat...
ryoungerca
GX - 2nd Gen (2010-2023)
29
Sep 4, 2025 08:09 PM
jgaynor
Aug 31, 2011 03:17 PM
4urxtc
Apr 24, 2011 05:32 PM
joelgs3
GS - 1st Gen (1993-1997)
Jul 1, 2007 04:38 PM
vassey50
Lighting
May 27, 2007 05:55 PM
