Battery drainage
Old Mar 8, 2024 | 08:24 AM
BABANEL's Avatar
BABANEL
3rd Gear
Default Battery drainage
Good evening everyone am happy to be here pls I need help on why my battery runs down after 10 hours thanks
Old Mar 8, 2024 | 02:31 PM
maxSteel's Avatar
maxSteel
Has the battery been tested?
Old Mar 8, 2024 | 02:38 PM
BABANEL's Avatar
BABANEL
3rd Gear
Yes this is actually the third battery am using now and whenever I pack and remove the terminal head of the battery I come back to start it one hand but when I leave the terminal head from evening to morning or for 10 hours the battery will run down
Old Mar 8, 2024 | 04:25 PM
salimshah's Avatar
salimshah
25 Year Member
I would start by charging up the battery. You may have to disconnect from the vehicle.
Then have the alternator tested. The alternator not only produces the charge voltage+current but can draw from the battery. When you have it tested, have them check for abnormal draw.
Remove any add on accessory [even if it had been working fine] as they are typically the cause of the problem.
Once that is done determine the vehicle off state current drain. Search on "parasitic draw". Keep in mind that the expected number will not be zero. More details are in the threads that the search will find for you.
You can start pulling out the fuses to determine which circuit is drawing the current in off state.
Salim
Old Mar 8, 2024 | 11:26 PM
BABANEL's Avatar
BABANEL
3rd Gear
Salim
Thank u very much for ur suggestions, the alternator has been serviced though but I will act on other options ur highlighted thanks 🙏
Old Mar 9, 2024 | 09:19 AM
salimshah's Avatar
salimshah
25 Year Member
Please do not go by assumptions. Likelihood of alternator being bad is low after service, but failure possibility is relatively high after service [infant mortality rate is usually higher]. I suggest reset and start afresh.
Salim
Old Mar 9, 2024 | 11:58 AM
Oro's Avatar
Oro
What does “serviced” mean? Alternators are sealed units and short of rebuilding them, there is no real service to be done. Salimshah’s advice is spot-on.
Check for a bad voltage regulator, or a parasitic draw. AC voltage across the battery terminals while running will indicate a bad VR in the alternator. It will drain down a battery overnight with no other symptoms, often.
Old Jul 19, 2025 | 05:33 AM
RCJ's Avatar
RCJ
7th Gear
Great recommendation. I have some work to go through but it's a great learning experience. Glad I don't have a full time job. Thanks again.
STerasedU
Sep 12, 2023 06:13 AM
MX73
Mar 7, 2022 10:17 AM
mate01
Aug 12, 2016 03:24 PM
