LSD RCF Differential fluid
Old Jan 8, 2023 | 05:52 PM
cvt's Avatar
cvt
Default LSD RCF Differential fluid
I have an RCF with an LSD and I’m getting close to getting it replaced.
what brand and weight do you guys use and how much fluid is needed?
Old Jan 8, 2023 | 06:30 PM
LoSt180's Avatar
LoSt180
LT 75W-85 GL-5 fluid
capacity: 1.38 to 1.47 US quarts
Brand is subjective, Mobile1 is readily available at local stores.
Old Jan 9, 2023 | 03:11 PM
jim2527's Avatar
jim2527
Does it require a friction additive?
Old Jan 10, 2023 | 06:38 AM
LoSt180's Avatar
LoSt180
Nothing in the manual about adding friction additive.
Old Jan 11, 2023 | 04:45 AM
AlexAviles's Avatar
AlexAviles
I have a ton of trust in The Car Care Nut. He suggests always using toyota diff fluids. Probably for a number of reasons, including having a lot of experience with toyota products. For me it makes sense because a well maintained Toyota or Lexus will have exceptional reliability. Sure you could argue that “I have a toyota with 300k and I always use Lucas fluids”. Well, there are a lot more toyota owners with 300k that were dealer maintained with 300k too. Arguably the more common story. Why research all these different types and wonder if you made the right decision.
ps when you do the change, be sure to grab the correct crush washer. It’s like a skinny little donut. I think this is the pn but you’ll want to double check it.
12157-10010.
Old Jan 11, 2023 | 06:09 AM
Patton6964's Avatar
Patton6964
I just went to the stealership and had them replace mine. $135, I thought that was a fair price considering I didn't have to do a darn thing.
Old Jan 11, 2023 | 11:28 AM
Moos0004's Avatar
Moos0004
Just because you are replacing at the dealership it does not automatically mean you are getting Toyota branded fluid in the case of a Toyota dealership. Carcarenut talks about this in detailed in one of video as most dealership buys whatever is the cheapest and that is what they use.so be sure to ask what brand.
Old Jan 11, 2023 | 02:18 PM
cvt's Avatar
cvt
This is what I got
Red Line 50104 75W85 Performance Lightweight Synthetic Gear Oil Fluid (2 Quarts) https://a.co/d/0rKocZ4
any experience with Redline 75W85?
Old Jan 11, 2023 | 02:21 PM
Patton6964's Avatar
Patton6964
They used part # 819195 which comes up as valvoline 75w90 full synthetic gear oil. Not sure if that is OEM or not. Frankly don't care as long as it keeps it working properly.
Old Jan 11, 2023 | 02:57 PM
jim2527's Avatar
jim2527
All of the options mentioned, Mobil 1, Valvoline, Redline, Royal Purple, Joe Gibbs, etc have friction modifier already added.
Was just wondering if the branded Toyota stuff had it…
Old Mar 13, 2023 | 09:29 AM
aaronsules's Avatar
aaronsules
9th Gear
Angry I had mine changed - i think!!
Originally Posted by patton6964
i just went to the stealership and had them replace mine. $135, i thought that was a fair price considering i didn't have to do a darn thing.
well, i supposedly had mine changed too at a shop in town - recommended shop. Got home, saw fluid on the ground below diff., took flashlight out and pointed at drain plug - full of road grime, plug obviously not been touched by human hands in years, still looking to see if fill plug had been removed (and maybe left out??? New caskets added????) am not happy at this point.
Old Mar 15, 2023 | 06:57 AM
Louczar1's Avatar
Louczar1
and this is why I always prefer to do all the maintenance myself.
Old Mar 15, 2023 | 10:11 AM
aaronsules's Avatar
aaronsules
9th Gear
Talking Do the work yourself
Agreed - i still can get my old bones to work!!!
Old Mar 15, 2023 | 10:27 AM
Yahya's Avatar
Yahya
7th Gear
  1. You should put GL5-75W-85 LX for LSD
I HAVE THIS CONFUSION ALSO
Hi guys i have 2018 is300 2.0l RWD
I noticed it doesn't mention what differential fluid it takes?
i did the GL5-75W-85 LT
and when I checked the rear wheel while the car on jack both wheels turns same direction not the opposite as it should for open differential!
my question is, whether my car is LSD so I should put differential fluid GL5-75W-85 LX?
​​​​​​​thank you
Yahya's Avatar
Yahya
7th Gear
Default Lsd
thank you
