Valley Plate video
Old May 1, 2020 | 04:24 PM
cvt's Avatar
cvt
Originally Posted by mike33
Thank you for correcting me...
Do you think you have a valley plate leak again now that coolant level has returned to the low line?
i don’t have an ISF anymore. When I had it and got the repair done I found that after 8 months (instead of 4) it went back down to low. I think they goofed on the repair. Many ISF guys have experienced having the O ring pinched that would lead to a “go back” on a repair. But many have had the repair done in one shot and no issues after.
Old May 1, 2020 | 04:53 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^From what I understand, a gasket or O ring is not used. It's sealed with an adhesive or sealant. There are two types as I understand it, and the recommended sealant was changed during the course of the ISF's production.
https://www.clublexus.com/forums/is-...y-plate-6.html
Lou
Old May 1, 2020 | 08:42 PM
cvt's Avatar
cvt
Lou
Post #355 from viperz...pcv box seals labeled as o rings....
Yes the sealant has changed but was this truly determined as the cause? Even Lobuxracer wasn’t sure.
Old May 1, 2020 | 10:21 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^viperz is talking about pcv box seals. He's mentioning other good things to do when performing the valley plate repair.
Originally Posted by viprez586
You'll want to replace the pcv box seals and i believe they list them as o-rings.
Lou
Old May 2, 2020 | 12:32 AM
cvt's Avatar
cvt
Lou
post 538 I think they Stuart mentioning about pinching the o ring. I believe the video I posted mentions an o ring as well right after he removes the intake manifold
Old May 2, 2020 | 01:03 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
There are two o-rings sealing the tube from the timing cover to the valley plate connection. If those are not installed correctly, and we've heard of a few cases on this forum where they were not, then you could still have a leak after the valley plate is fixed and properly sealed.
speedkar9
Feb 27, 2020 07:00 PM
Hoovey689
Jun 8, 2018 11:39 AM
SoCal35
Jun 9, 2010 01:39 PM
BlackGhost
Oct 20, 2008 11:18 AM
onsknht
79
Jan 22, 2007 05:23 PM
