Intake Manifold Port work!!
Old Mar 10, 2020 | 02:40 PM
LRCSALES's Avatar
LRCSALES
Default Intake Manifold Port work!!
Hey everybody I have just dropped off my intake manifold for my RCF to a machine shop that is going to do some port work on the runners and behind the throttle body since the throttle body is not as wide as the mouth of the manifold so they're just going to make the entry smoother there and then basically bore out the runners where they meet the heads there's a decent amount of aluminum to be removed. I provided a photo hopefully we'll have the manifold completed by next week then I can give you guys some more photos and the reason I have taken off on manifold is to upgrade my Nitrous system which is still top secret lol
*small fyi our manifolds are made by Yamaha*
Below stock imported RCF manifold. With gasket
Above 2 photos. Are of a ported rcf manifold. See below post for gasket on a stock unported head
Old Mar 10, 2020 | 03:20 PM
cvt's Avatar
cvt
Would the increase in flow affect your oem tune? Very interesting. I'm curious to see how it goes.
Old Mar 10, 2020 | 03:51 PM
LRCSALES's Avatar
LRCSALES
I'm already tuned so we will find out
Old Mar 11, 2020 | 11:03 AM
JT2MA71's Avatar
JT2MA71
Good stuff! How much bigger are the intake ports on the cyl. heads? Much closer to the gaskets?
Old Mar 11, 2020 | 04:03 PM
Fysisist's Avatar
Fysisist
Also curious about cost and if the machine shop is making any statements about how this will improve performance? I mean we all know it should improve performance, more air volume, less turbulence, etc, but I guess the question is how the ECU / tune reacts to it.
Old Mar 12, 2020 | 07:19 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Pretty rare for this kind of work to make significant impacts. The last 1/2" of the intake port is where the real work gets done and where the factory only pays lip service when they install the valve seats.
If the shop makes any claims at all, they're fools unless they've already done this work on a number - at least 5 - of these units and have some direct experience with the results.
Old Mar 13, 2020 | 01:58 PM
LRCSALES's Avatar
LRCSALES
Picked up. After photos added!! I'll get the pic of the throttle body opening. Only $250! Took 4 days
Old Mar 13, 2020 | 02:00 PM
LRCSALES's Avatar
LRCSALES
Lets all take a step back from the "this won't work for gains talk " my manifold is already off as I previously stated for redoing my nitrous setup so I thought I might as well gasket Port match the manifold so let's all relax all I did was Port match my manifold I knew that I wasn't gonna see gains esp in NA format. I'm going be spraying nitrous directly into each cylinder. So more room for fuel and nos to mix so better for me.
Old Mar 13, 2020 | 03:32 PM
LoSt180's Avatar
LoSt180
Looks great. Nothing wrong with trying to squeeze out every drop of performance.
Old Mar 13, 2020 | 04:22 PM
JT2MA71's Avatar
JT2MA71
Can you post a picture with the gasket on the cyl. head? Are the ports actually the same size as the holes on the gasket? Thanks!
Old Mar 13, 2020 | 05:34 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
+1. Would love to see the port size in the head relative to the gasket size.
Old Mar 13, 2020 | 06:45 PM
LRCSALES's Avatar
LRCSALES
^above is a none ported head. To stock gasket
^ this is ported (GASKET MATCHED)
Old Mar 13, 2020 | 06:49 PM
LRCSALES's Avatar
LRCSALES
Updated see above
Old Mar 14, 2020 | 09:38 AM
JT2MA71's Avatar
JT2MA71
Looks good! What we don't want is the intake ports being bigger than the cyl. head ports. Looks like they are very close match now!
Old Mar 14, 2020 | 11:22 AM
LRCSALES's Avatar
LRCSALES
Yeah it's decent. I thought about having the heads done but estimates I got from a diff shop were almost 4k
