CF plate - is this normal?
Old Dec 25, 2019 | 03:32 PM
baboya96's Avatar
baboya96
Default CF plate - is this normal?
Just noticed yesterday that edges around door switches (both doors) are somewhat ‘peeling’. It’s showing very small ‘white’ bubbles as if CF coating is coming off. Is this normal? Has anyone had this experience? Would this be covered under the manufacturer warranty or considered ‘wear/tear’?
Hope you can see in these photos. Driver side is more noticeable at the top.
Old Dec 25, 2019 | 04:13 PM
05RollaXRS's Avatar
05RollaXRS
Take it to the dealership. Not normal and they should fix it.
Old Dec 25, 2019 | 07:33 PM
MCB1970's Avatar
MCB1970
I had mine replaced under warranty along with the nav screen.
Old Dec 25, 2019 | 09:19 PM
BlueRCF10's Avatar
BlueRCF10
I also got the CF trim replaced under warranty.
what was wrong with the Nav screen?
Old Dec 26, 2019 | 06:18 AM
MCB1970's Avatar
MCB1970
The anti reflective coating was peeling around the edges. I guess it was common problem on 2015 RCFs and other Lexus models.
Old Dec 26, 2019 | 05:56 PM
baboya96's Avatar
baboya96
Thanks for the response. I’ll make an appointment and see what the local dealership is willing to do. Hopefully no push back.
Old Dec 26, 2019 | 06:45 PM
MCB1970's Avatar
MCB1970
As long as you are still under warranty they should not give you a problem. I was having my rear struts replaced because they were leaking. Previous owner had the car lowered on RSR springs. I put the OEM springs back on and took it the dealership. While in the waiting room, I googled “things to be checked before RCF warranty expires.” The dealership did not question anything and I didn’t even purchase my car through them. Part of the reason why my next car will be another Lexus. They stand behind their products!
Old Dec 27, 2019 | 08:59 AM
BlueRCF10's Avatar
BlueRCF10
I second this. I wasn't the original first owner either and they went above and beyond with everything. But I guess that's what warranty is for
RCFGrandpa
Mar 25, 2026 06:45 AM
Sit
RC F (2015-present)
Apr 25, 2019 11:23 AM
Luisvm
Jun 1, 2015 10:38 AM
2jz-sc
Jan 6, 2011 07:50 AM
Evitzee
Aug 17, 2010 11:24 AM
