HELP! How to remove wheel adapter?
I'm taking off the Vossen CVT wheels and installing the stock wheel/tire combo as I'm getting the car ready for its new owner, but the adapter is stuck. I noticed that there are threaded holes which would move the rotor with the adapter off the hub, but I don't know the bolt pattern screw to purchase. Anyone know?
Last resort would be to remove the caliper and hit the rotor from the inside with a rubber mallet.
Do you not have a bucket of random bolts from cars you've collected over the years? Just try one until you find something that fits. Looks like an M8 or M10 sized hole, thread pitch is most likely 1.5. Can be found at any local auto parts store.
That bolt hole is there for the problem you are having. It was also on the ISF. Assume the bolt hole spec. is the same:
https://www.clublexus.com/forums/is-...moval-tip.html
Lou
Lou
Lou
Lou
