TPMS problem
Old Oct 17, 2019 | 01:06 AM
Rozay604's Avatar
Rozay604
Default TPMS problem
Anyone here have the same problem as me. After i change to aftermarket wheels with aftermarket Tpms sensors the car does not display PSI on the screen, i got them copied to the factory id's and i went as far as getting a different set of tpms program with random id's and i still get nothing. I have all the tools to program the id's and program to the car. Any help would be great
Old Oct 17, 2019 | 06:28 AM
MrJeager's Avatar
MrJeager
I would check the frequency of the aftermarket TPMS sensors - It could possibly be the wrong frequency - RCFs run at 315 MHz. Another reason could be that there is a duplicated ID (two or more sensors that have the same ID), in this case, the car computer will not show any values.
I had recently purchased replacement sensors from Autel that have dual band frequencies, metal stem, and come with the wireless programmer.
Old Oct 17, 2019 | 03:00 PM
MoarLow's Avatar
MoarLow
Same issue for me, my screen does not display the numbers after using an aftermarket TPMS
Old Oct 19, 2019 | 02:07 AM
Rozay604's Avatar
Rozay604
My sensors are hybrid they do both frequency. I even check them on Techstream live data and its working perfectly. it just wont display.
Old Oct 20, 2019 | 07:13 PM
MoarLow's Avatar
MoarLow
I'm going to try and reset mine from the dash screen. I will let you know if it ends up working.
Old Oct 29, 2019 | 10:01 PM
3GSShoe's Avatar
3GSShoe
I thought you could clone the sensor ID's using the new MAXITPMS Autel Sensors (as a second set) but as long as you don't have both sensors with the same ID near the car, then it should be okay?
Old Oct 31, 2019 | 07:57 AM
EJC's Avatar
EJC
Yeah, I had similar last year when putting snows on my wife's ES. I bought a set of mounted snows with aftermarket TPMS sensors. NO PSI numbers. We ended up returning the wheels and tires and just getting snows for the Lexus wheels.
Old Oct 31, 2019 | 11:10 AM
MrJeager's Avatar
MrJeager
I have recently installed the same autel aftermarket sensors that i have posted above. Get the Carista App with the OBD2 dongle and read what your current IDs are. It could be that the car's sensor IDs are blanked / wiped out, if so, generate random IDs and program the car as well as the sensors using Carista, and the TPMS wireless programmer (if going with the same Autel sensors as above).
Below are some quick pics of pre-and-post install. Ready for winter.
Post back with your findings, best of luck!
jdpdata
Oct 8, 2018 08:53 AM
SNiiP3R
Jan 9, 2015 03:41 AM
01LEXPL
Wheels, Tires & Brakes Forum
Oct 9, 2013 08:49 PM
LEXJG
Feb 13, 2012 04:30 PM
ApoK
Sep 27, 2008 01:18 PM
