Creaking/ thumping sound from sunroof
Old 10-30-17, 04:36 PM
NYCRC
NYCRC's Avatar
Default Creaking/ thumping sound from sunroof
Has anyone experienced a creaking/thumping sound coming from their sunroof? It mainly happens if I go over a bump while turning or need to go up a steep incline at an angle.
Old 10-31-17, 02:33 PM
tarponman
tarponman's Avatar
I think I experience something similar. Make sure the shade that pulls over the sunroof is completely pulled back when its open. I've noticed that helps.
Old 11-01-17, 07:48 AM
Ne1tHeRe
Ne1tHeRe's Avatar
Never. That is not normal.
Old 11-01-17, 04:59 PM
NYCRC
NYCRC's Avatar
Thanks. Wanted to make sure I wasn’t the only one. It happens with the sunroof closed. I’m thinking it might be triggered by the rough NYC roads and being lowered on Swift springs. I’m hoping the dealer doesn’t blame it on that when I take it in.
Old 11-04-17, 12:14 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
It's chassis flex. They'll blame it on anything but the car.
More than likely they will take some dry silicone, spray all the seals, and ensure all the fasteners are properly tightened. There's not much else you can do, and often this fixes the issue unless there is a bad spot weld somewhere.
Old 11-19-17, 06:33 PM
2Insane
2Insane's Avatar
I have the same noise coming from the sunroof. Definitely notice going over speed bumps. These NYC streets are a nightmare, lol.
Old 11-21-17, 07:51 PM
al503
al503's Avatar
Try a search for Gummi Pflege. I had the creaking issue in my 2IS and one application of the GP would take care of it for a couple years.
Old 11-28-17, 05:12 PM
NYCRC
NYCRC's Avatar
Thank you. Gummi Pfledge did the trick. I applied it to the rubber around the sunroof and the noise is gone.
Old 11-28-17, 05:27 PM
mjeds
mjeds's Avatar
yes I had the creaking and thumping on my RC-F since I bought it, after 2 years I finally got tired of it and complained to the SA when I went in for my 15K service.. My entire sunroof unit was replaced under warranty, the rails, motor, track, everything..
the tech discovered along with the thump and creak, that my roof also did not open fully, when measured and compared to other RCs and RC-Fs on the lot, it was a full 2 inch difference in the opening size.
I posted about it awhile back, while the idea of having basically the whole interior and the rear windshield removed as to replace the unit bothered me and caused a but of stress, the dealership did an excellent job, no damaged panels or paint, no new rattles or noises, and with the sunroof opening completely the odd buffeting sound I used to have is gone.
When I posted about it, 4 other RC-F owners PM'd me that they had similar issues with their 2015, I know 2 of those 4 also had their whole unit replaced.
CobraGSF
GS F (2016-present)
08-02-18 08:07 AM
amcdonal86
15
06-07-10 12:33 PM
cute_es350
ES - 5th Gen (2007-2012)
11-28-09 07:42 AM
jimjaix
03-29-08 01:42 PM
CarDudeRI
08-21-06 07:09 PM
Quick Reply: Creaking/ thumping sound from sunroof
