Any ride quality issues with RR Racing USRS
Old Sep 22, 2017 | 08:50 PM
konichiwa3's Avatar
konichiwa3
Default Any ride quality issues with RR Racing USRS
I am considering the RR Racing ultimate steering response system (USRS). http://www.rr-racing.com/Lexus-Lower...isfxlca001.htm Anyone install on their RCF? Do you notice increased NVH? 95A durometer for the bushing seems pretty hard. Worried about impacting ride quality. Mostly be doing street driving (albeit spirited )
Old Sep 22, 2017 | 10:15 PM
Kramer's Avatar
Kramer
I've had mine installed for about 2 months now. Steering is much more responsive and hard braking car is very stable. It doesn't want to dash or pull anymore under hard braking. The Durometer hardness of the bushing reduces that flex as seen in their video. It doesn't affect the ride quality all that much because the rest of the suspension still revolves around a ton of rubber bushings.......you're only swapping one....I had it on my IS-F too for over 2 years. NVH is "oh so" slightly harsher, very negligible, but well worth the trade-off. I hope this helps! It's a very worthy inexpensive upgrade!
Old Sep 22, 2017 | 10:20 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^^As said, NVH is a bit harsher, but the handling improvements far outweigh the slightly harsher ride. I wouldn't be be without 'em
Lou
Old Sep 23, 2017 | 12:48 AM
Suburbazin's Avatar
Suburbazin
I've had mine in for about a year now, no alteration to ride quality although handling became much better, especially on crowned roads and well-traveled lanes. It's not particularly noisier either, although the bushings will become fairly talkative when turned fully to lock left/right.
Probably the biggest, most convincing difference is getting more than 6K out of front tires. Changing tires and oil was getting old.
Old Sep 23, 2017 | 06:52 AM
GetKinetic's Avatar
GetKinetic
Sorry. What is NVH?
Old Sep 23, 2017 | 08:17 AM
JT2MA71's Avatar
JT2MA71
Originally Posted by PunisheRCF
Sorry. What is NVH?
Noise, Vibration, Harshness.
Old Sep 23, 2017 | 09:25 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Sorry. What is NVH?
https://en.wikipedia.org/wiki/Noise,..._and_harshness
Lou
Old Sep 25, 2017 | 02:27 AM
isfvss's Avatar
isfvss
Put them in 1 month ago very small ripples and can be felt, but the steering response has been tightened up, brakes very straight, big bumps = no wander. Very easy to put in on jack stands ( hey Lou ) if you don't like them you can sell them very quick, no brainer cheers.
Old Mar 31, 2021 | 06:57 AM
nigel821's Avatar
nigel821
I'm on the fence between the their street racing version:
Lexus Lower Control Arm (LCA) Bushing (rr-racing.com)
Or possibly their original even though I think the original is going to be too much for me.
I am also looking at Fig's: This is designed differently so that bushing does deflect and move unlike the RR racing one that there is zero movement.
2006+ IS/GS RC RC-F Front Lower Arm Rear Mount #2 Polyurethane Bushing 90 HIGH PERFORMANCE INSTALLED IN BRACKET (shopfigs.com)
I know we have F cars but I want to make sure and keep comfort and the "Lexus" feel. I went too nuts with my STi and replaced everything with poly bushings and suspension pieces and it's just too harsh of a ride on the street. Extremely planted and awesome feeling but after some time your body hurts... I don't want that at all with the Lexus. I have not seen any reviews on the street version of RR racings USRS system though..
-Nigel
Old Mar 31, 2021 | 07:31 AM
GetKinetic's Avatar
GetKinetic
-Nigel
street version is great! Ride doesn't change. the steering response does. I find ride quality is all about your coil setup . I say go for it. I have a gently used set avail able,, if you want, as I upgraded to track version along with the rr coils. Pm me or hit me up in the Lexus RC F Owners fb group
Old Jul 9, 2021 | 12:42 PM
drutyper's Avatar
drutyper
Im debating between the two LCA track edition and the LCA road&track edition. What are the noticeable differences between the two? Is the extra cost of the Track edition worth it?
Old Jul 9, 2021 | 01:13 PM
05RollaXRS's Avatar
05RollaXRS
The track version is stiffer with spherical rings so it is as solid as it can get. It will give you a very stiff and immediate sharp response on the front end. However, it will compromised on the streets as you will feel a lot more NVH. Also, longer term you will have to grease it again otherwise, squeaking is a probability. The street version is a bit softer, but still stiffer than OEM bushing. It strikes a balance between spirited/track driving and streetability. If you take it to the track a lot then track version is the better choice, but if you are going to drive primarily on the streets with some occasional track driving then the road and track version is better.
Old Jul 12, 2021 | 07:35 AM
nigel821's Avatar
nigel821
I never updated with what I bought back in March when I posted in this thread asking questions. From everything I gathered and all the reviews, I went with Figs 90 Dur poly bushing. Seems to be the best in terms of almost no NVH and for a car that isn't going to see the track EVER, I wanted to keep the comfort and also address the inner tire wear that people have. I've read zero complaints with Figs.
I was planning on installing them when I got my exhaust but that's been pushed back for several months again so I will probably just get the car on my lift and install them here in a weekend or two. Install looks super easy, and then I'll just drive it to the dealer and get an alignment. I believe the key for when one installs the bushings is to make sure they make the toe 0. (Correct me if I am wrong)
Thanks,
-Nigel
Aron9000
Jan 9, 2018 01:58 AM
uncandid
Suspension
13
Oct 3, 2012 02:33 PM
MrDDub
IS F (2008-2014)
14
Nov 14, 2007 08:51 AM
GGGXXX
GX - 1st Gen (2003-2009)
May 2, 2007 12:34 PM
kam1996
Suspension and Brakes
Nov 15, 2003 12:34 PM
