Shift knob loose
Old Nov 9, 2015 | 11:03 PM
ZiPPyRCF's Avatar
ZiPPyRCF
Default Shift **** loose
I went to upshift today and I felt my **** turn. I'm still shifting with the shifter, as I'm used to manual from my Z. Slowly getting used to the paddle shifting.
But has anybody had an issue with the shift **** being used? WTF?! That shifter should be hella solid, no questions asked.
And just to add, as I saw a similar issue in the IS350. When I twist it tighter, the shifting path is almost no give, as though the more I twist the less room it has to shift. If that makes sense. A little irritated, because I love this car but damn do I miss shifting a manual.
Old Nov 10, 2015 | 02:47 AM
kabgolf1's Avatar
kabgolf1
I had the issue with my RCF, IS350, and my Toyota Tacoma pickup. All of them needed one extra turn but there was no difference in the shift lever itself. The **** just no longer moved.
It is easy to fix. The metallic piece right at the base of the **** that connects to the boot just pops down. Pull it down and then just turn the **** and then just click the piece back into place.
Old Nov 10, 2015 | 04:52 AM
4everkidd's Avatar
4everkidd
same issue here, thanks for the tip.
Old Nov 10, 2015 | 08:43 AM
LRCSALES's Avatar
LRCSALES
as a lexus salesman every new car i get in. i pull down the boot and give it one more turn. then it is perfect.
Old Nov 10, 2015 | 03:41 PM
ThaDRD's Avatar
ThaDRD
How much effort should it take? It seems like that collar won't move with a decent amount of force using just my hands.
Old Nov 10, 2015 | 03:42 PM
method3d's Avatar
method3d
Picked up my car today and noticed the same issue. Kinda annoying. Thanks for the tip though.
Old Nov 12, 2015 | 09:32 PM
ZiPPyRCF's Avatar
ZiPPyRCF
Thank you mate!! I was able to tighten the ****, and it's perfect now.
isam250
General Classifieds
Aug 18, 2015 06:56 PM
BOOOGS
IS - 1st Gen (2001-2005)
Nov 22, 2012 02:10 AM
hellasboy
Jan 19, 2008 09:34 PM
