Active Wing Stuck / Not Functioning
Old Apr 2, 2018 | 07:46 AM
  #121
Ninja10r's Avatar
Ninja10r
well looks like my rear wing has an issue , so it won't go up at 52 mph and is stuck in the down position , and the wing go's black on the dash, i like the auto setting, because i get a kick out of the look on people's face when i come to a stop and the wing go's
down or how it raises as i'm pulling off from a light .......going to the service dept on Wednesday
Old Jul 7, 2019 | 02:05 PM
  #122
3BUD's Avatar
3BUD
Default Active Wing Stuck ( 2015 RC-F)
Hello everyone,
I recently had an issue with my rear wing as well, but it got stuck in the down position while on the screen it shows that the wing is up in its high / active position and the active wing control button stays lit as well.
I have tried pressing the button but nothing happens. When I hold the button, the light becomes dimmer ( does not turn off completely ) and I see the wing retracting in the screen animation but it goes back up immediately and it stays green while physically the wing stays put in the low position without even moving although I do hear sounds from the motors.
Has anyone experienced similar issues with their RC-F ?
Thank you for any useful information and for your time .
Old Jul 7, 2019 | 10:19 PM
  #123
lexusrus's Avatar
lexusrus
There is a TSB for this. Free fix. I had mine done about a month after I got my RCF.
Go to a Lexus dealership QUICK before the warranty runs out!!!
Originally Posted by 3BUD
Hello everyone,
Old Jul 8, 2019 | 02:07 AM
  #124
3BUD's Avatar
3BUD
Thanks, if any updates are available I’ll post back.
Old Jul 8, 2019 | 09:43 AM
  #125
lexusrus's Avatar
lexusrus
Please see attached.
File Type: pdf
Old Jul 8, 2019 | 12:29 PM
  #126
3BUD's Avatar
3BUD
Thanks a lot
Old Feb 25, 2020 | 10:11 PM
  #127
AyoItsPat's Avatar
AyoItsPat
Thanks a lot
Were you able to get your wing fixed by the dealer?
My 2016 just got the same issue that you got, says wing is up and is lit green but it is actually down. When I press the button I can hear the motors moving but on the screen i can see it try to go down but come back up (wing never moved from down position)
Old Feb 26, 2020 | 12:54 AM
  #128
lexusrus's Avatar
lexusrus
It's a free fix at Lexus dealerships under warranty.
Old Feb 26, 2020 | 11:09 AM
  #129
ZiPPyRCF's Avatar
ZiPPyRCF
I'm trying to get Lexus to fix it, as I'm out of warranty but when it was in they went ahead and said they would fix it. I don't see them referencing any TSB, so not sure what "fix" they did. It stopped working after about a month after Lexus looked at it. I might be forced to just leave it up all the time, which I do like. But it's cool to have it go up and down, I've always liked that feature.
Just curious. After you guys got the fix, has it been holding up? I've seen a couple comments about the motor, and others about a reset.
Cheers,
Old Feb 26, 2020 | 10:26 PM
  #130
ZiPPyRCF's Avatar
ZiPPyRCF
Going on 2 days now to get a call back from my advisor, as the fix was to turn my spoiler options back on. I had manually set it to stay up, and they think that was the problem. What a joke! They should know damn well this is an issue, and be proactive about the fix. Now I'll have to pay out of pocket for this fix, which I know won't be cheap.
I'm hella busy in my profession, but I always make time to call back clients. Really? You talk to a customer for a few minutes ..."oh you need an oil change? oh you need that service?" and you turn in the paperwork have the customer sign in and next customer. It's not that hard of a job. I'm seriously pissed. This is the 3rd time with this damn dealership regarding crappy communication. Because a call or text is so damn difficult to send out.
Old Feb 27, 2020 | 01:28 AM
  #131
lexusrus's Avatar
lexusrus
Mine is working fine after the fix some 4+ years ago. No problems.
Cheers,
Old Mar 3, 2020 | 01:41 AM
  #132
cvt's Avatar
cvt
I just bought mine with 60k miles. Looks like my VIN is affected but I’m out of warranty. The previous owner hasn’t performed the tsb. Wing still works but seems like a matter of time before it doesn’t. I’ll just leave it down for now until I can find more economical ways to fix. Dealers are quoting me between $1,400 to $3,000 to fix out of pocket
Old Mar 3, 2020 | 06:05 AM
  #133
05RollaXRS's Avatar
05RollaXRS
I don't believe TSBs are affected by warranty. You should still take it back to the dealership. They will perform the ECU update for you for free.
Old Mar 3, 2020 | 07:32 AM
  #134
cvt's Avatar
cvt
It says good for only 48 months or 50,000 miles. I’m wondering if it’s just cheaper to have them reset it every 500 times like an earlier poster said
https://www.clublexus.com/forums/att...ctive-wing.pdf
Old Mar 3, 2020 | 02:43 PM
  #135
LoSt180's Avatar
LoSt180
TSBs are NOT recalls, I repeat, TSBs are NOT recalls. They're simply a way to help technicians troubleshoot problems much quicker. Basically the official version of "oh yeah, I've seen that problem before and here's how to fix it."
If you're still under warranty, then the fix is covered. If you're out of warranty, then you'll have to pay, just like any other service out of warranty. If you have a good relationship with dealer, they may do a good will fix, but if you're the kind of person that only shows up for recalls, they probably won't be too inclined to give you free services.
