Front Brake Rotor size
Old Apr 6, 2021 | 06:57 PM
JPhsieh's Avatar
JPhsieh
Default Front Brake Rotor size
I was given smaller rotors than what was on my car. I tried purchasing from both Amazon and Oreillys and both have me 13” rotors when the ones on my car are 14”. Has anyone had this issue or has anyone gone with 13” Rotors?
Old Apr 6, 2021 | 08:57 PM
CLightning's Avatar
CLightning
IMHO, if your original rotors were 14" (356mm), then you need to stick with the same size. The 13" ones will work for a while, but then when your pads wear out, you'll end up with this:
...and when your rotors and pads wear down past their minimum thicknesses (<27mm and <1mm), I can see a higher risk of something catastrophic. You do the math.
Old Apr 6, 2021 | 10:45 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
You would need to swap your calipers and so on if you wanted to change to the smaller brakes. Go for the correct rotors.
Jeff
Old Apr 7, 2021 | 08:22 AM
Fithamoto's Avatar
Fithamoto
I believe you will need to get the 2 piece hat rotors. They are for the F sport models.
Old Apr 7, 2021 | 01:17 PM
jonmonkey's Avatar
jonmonkey
I have a spare set of drilled and slotted rotors from mine....used for about 500 miles.
Old Apr 7, 2021 | 02:25 PM
Fithamoto's Avatar
Fithamoto
jonmonkey, why did you take them off? were they squealing? I might be interested in them?
Old Apr 7, 2021 | 02:27 PM
jonmonkey's Avatar
jonmonkey
Upgraded to a big brake kit.
Old Apr 7, 2021 | 03:15 PM
Fithamoto's Avatar
Fithamoto
What pads were you using with them? And what brand are they? I want to put some drilled slotted rotors on with new pads. Tell me what you were running.
Old Apr 7, 2021 | 03:43 PM
jonmonkey's Avatar
jonmonkey
Ran this kit.
Och
Aug 25, 2021 01:30 PM
EuroWill
Suspension and Brakes
Dec 10, 2019 05:59 PM
warminwisc
Oct 4, 2019 03:03 AM
LexiGS4ty
Apr 2, 2012 07:09 PM
