Remove rear console
Old Jan 26, 2020 | 10:29 PM
Beto3214's Avatar
Beto3214
Default Remove rear console
Anyone know how to remove the rear console?? I want to replace it with the rcfs
Old Jan 29, 2020 | 03:54 PM
Hhatch's Avatar
Hhatch
You have to remove the rear seat bottoms. Pull up on the front edge of each side. The two sides and console come out together as one piece. You will likely snap the white clips, but they are cheap to replace. Once out, flip it over and the console slides forward and out. One end is pinned by a metal rib that you have to work over a lip. You do not need to release any of the fabric or leather bits attached to the center frame.
Old Jan 29, 2020 | 09:16 PM
jaywuzhere's Avatar
jaywuzhere
@Beto3214 I added a USB fixture to my rear console. Did a write up here: Adding a USB to the Rear Console. Most important take away from it, dont try to remove the rear console without first removing the entire rear seat. I tried to take a short cut, and broke some tabs. Added some plastic putty to fix it all and its installed just fine again lol.
billbarker
IS C
Mar 15, 2015 11:09 PM
hahahaf
IS F (2008-2014)
Apr 18, 2014 04:38 AM
cazz1911
GX - 1st Gen (2003-2009)
Jul 14, 2008 03:48 PM
johnnay
May 17, 2006 09:04 PM
