Squeaking noise when going over bumps *sometimes*
Old Oct 31, 2019 | 04:34 PM
sideswipe's Avatar
sideswipe
Default Squeaking noise when going over bumps *sometimes*
Hi All
I'm hoping someone has seen this issue or can give suggestions on a fix. Lately, when I go over bumps I hear a squeaking noise that sounds like its coming from the front end. It doesn't happen over *every* bump, only sometimes. I'm lowered on OEM lowering springs with no other suspension mods. I had it at the dealer for service and they claimed not to hear the noise and their suspension check said everything was A-OK. Let me know what you think or if you have any suggestions on what to check. I did see some threads suggesting the door or hood bushings might need to be greased or adjusted and I checked that and they appeared OK. Thanks in advance.
Old Oct 31, 2019 | 07:41 PM
nelBi's Avatar
nelBi
Could it be the front struts? I know they wear out faster on lowered vehicles. I've replaced mine already. How many miles are on your car?
Old Oct 31, 2019 | 09:28 PM
sideswipe's Avatar
sideswipe
59k miles currently but I only lowered it about 3k miles ago.
Old Nov 1, 2019 | 06:53 AM
Gremluc's Avatar
Gremluc
Agree with nelBi - front struts.
Old Nov 1, 2019 | 07:01 AM
sideswipe's Avatar
sideswipe
Thanks guys. I'll have those checked by an independent shop.
sideswipe's Avatar
sideswipe
What did you replace them with? OEM?
Old Nov 1, 2019 | 09:00 PM
nelBi's Avatar
nelBi
yes, I went OEM. My mechanic gives me heavy discounts on labor as long as I buy everything OEM lol
Old Nov 7, 2019 | 09:50 PM
zhanhugo's Avatar
zhanhugo
The noise apparently comes from the two-piece rotors that these f sports come with, I thought the noise came from the lowering springs being installed wrong but after asking my shop to reinstall the lowering springs and also checking in with my local Lexus dealer, I have concluded that the noise probably came from the two-piece rotors somehow hitting each other over bumps and under braking. I always hear the squeaky noise as I am backing out of the garage(slowly releasing the brakes), and also coming to a stop(slowing applying the brakes). So I wouldn't worry about it if you can make sure the struts and the springs were installed correctly and torqued to the right specs.
Old Nov 8, 2019 | 05:27 AM
sideswipe's Avatar
sideswipe
Thats good info and once I take it to the shop to have everything checked and all is OK, ill chalk it up to this,. The only thing is, it didnt always make this noise. It only started happening recently as far as I can tell.
Old May 28, 2020 | 12:30 PM
sideswipe's Avatar
sideswipe
As a follow up, this is still not resolved. The noise does not occur only under braking and the dealer claims not to hear it.
Old May 29, 2020 | 06:29 AM
radiant350's Avatar
radiant350
I had a slight squeaking noise come from the front end of my 2015 RC 350 F Sport. I noticed it while driving over bumps occasionally. I realized I could replicate the sound if, while parked, I leaned down on the front of the car. I figured it was something suspension related, but it turned out to be the hood latch. Once the dealer replaced it, the sound was never heard again.
I could see hard breaking or bumps making similar sounds, so I would suggest seeing if you could replicate the sound while parked and then inquiring about it being one of the hood latches. I don't have any more detail than this, as this is all the dealer told me.
Old May 29, 2020 | 01:16 PM
sideswipe's Avatar
sideswipe
Thanks for the tip, tried it an no squeak. Just picked it up from the dealer for an oil change and asked them to check and they claimed not to hear it either. Of course I heard it as soon as i drove off the lot. I'm considering taking it to an independent suspension shop to have it looked at.
Old Jun 1, 2020 | 01:53 PM
baco's Avatar
baco
This issue sounds like it should happen on every bump. I had this issue on my rc <400 miles. Took it in and they tightened the power brakes and voila. Gone. It did come back though after driving 5k miles.
Old Jun 1, 2020 | 01:57 PM
sideswipe's Avatar
sideswipe
That's the part that is driving me crazy, its not consistent. I agree, it should be every bump but it isn't. I checked the hood latch as well and that's not it. It also does not happen while braking, just slow speed driving is where I notice it the most. The dealer couldn't reproduce the sound so I'm taking it to an independent shop on Thursday to have everything checked to see if I can get this sorted out.
Old Jun 1, 2020 | 02:00 PM
baco's Avatar
baco
Yeah it happened on speeds under 30. Probably around neighborhoods with cracks and sewers on the roads. I hope the shop can take care of it. It's really annoying when you want to cruise with windows open.
