posting pics
I have some wheel pics I want to post.
1. Click on the pic you want to use. once it comes up
2. Right click on it and select properties
3. Highlight the address and copy it
4. Come back to the post and click on the IMG tag
5. Paste the address in there and post it up!!
Hope this helps!
GS4fun, I'm going to need a little more instruction for your method. I have windows xp My Pictures program. I tried resizing, changed some settings but they didn't stay. Can you give more specific instructions? Thanks.
Thanks DGOT20s, it worked.
Start Menu > All Programs > Accessories > Paint
Open the Paint program and then open up the image file you would like to edit using the program.
Once you have opened the image within paint...do the following to shrink the size of the picture:
1. select "image" and then "Stretch/Skew"
2. a new window will pop up, you want to enter the same smaller percentage values for the "Stretch" section for both horizontal and vertical values. for the example 50% and 50%. then hit ok.
3. use "save as" to save you file so that you don't lose your original:
file > save as
4. you want to save the file as a .jpg type file. just click the drop down box and select "JPEG" and then type in a name for the picture. then you are all done.
see picture below for demonstration. if the picture is still too big for upload (over 100 KB), then size it down more.
