TRD airfilter for 98+ GS3
Old Oct 23, 2003 | 02:17 PM
Rockero28's Avatar
Rockero28
Lightbulb TRD airfilter for 98+ GS3
What will the effect be in using this over the stock air filter? Change in sound? Peformance? Durability?? Worth the price?
Thanks,
Rock
Old Nov 3, 2003 | 05:36 PM
camtrek's Avatar
camtrek
go with a K&N instead.
change in sound at WOT.
a tad more peppy when using E-shift and slighty with normal.
durability wise...they are easy to clean and last a while.
btw. remove the lid to the airbox.
Old Nov 3, 2003 | 05:44 PM
Rockero28's Avatar
Rockero28
Default air filter
I am not too clear on what you mean bro..... CAn you clarify for me. It will be a little louder? And the filter goes in the air box right??
Thanks,
Rock
Old Nov 3, 2003 | 05:58 PM
camtrek's Avatar
camtrek
well once you give it some punch it will go "OOOMPH" making a very deep sound, and yes you slip the cover off of the air box and pop in the filter.
Old Nov 3, 2003 | 11:38 PM
Rockero28's Avatar
Rockero28
Thumbs up air filter
Ok, cool. So at idle it won't be any diferent then right? I was hoping to get a little more umph at idle.
Thanks though/....
Rock
Old Nov 4, 2003 | 12:44 PM
camtrek's Avatar
camtrek
It would only make a difference when air is being sucked in.
Old Nov 4, 2003 | 01:37 PM
KVA's Avatar
KVA
You have quite a few choices for aftermarket drop-in air filters: TRD, Tom's, Blitz, K&N, ProLex...
All of these will provide you with much more satisfaction over the OEM stock air filter. Performance-wise you should notice the change immediately, and most of these filters are very durable and manufactured to be cleaned and re-used over and over. You should only notice a slight change in the sound...but definitely a positive in my book. The upfront cost is definitely more, but down the line you will not have a need to replace the filter (thus the cost savings).
You will also need to adjust the springs inside the air filter box in order to hold the filter in place...most of the aftermarket filters are thinner then the OEM filter.
I wouldn't hesitate a second to change out the filter...and if cost is an issue, go with K&N as it is probably the cheapest of the bunch and can be bought from almost any local auto retail store (pep boys, trak auto, etc...).
Performance between all these filters has probably been discussed on this board previously, but in general they are all better then stock.
Old Nov 4, 2003 | 02:36 PM
camtrek's Avatar
camtrek
if you get the K&N as i did make sure you are getting the GS300 model.
It comes with a mounting rack for the filter that will slip right into the airbox and stay thee.
Old Nov 4, 2003 | 03:51 PM
Rockero28's Avatar
Rockero28
Thumbs up filter
Ok, cool. i actually went out and bought a TRD filter, so hopefully I will be satisfied. Thanks for all the scoop.
Rock
Old Nov 4, 2003 | 08:00 PM
camtrek's Avatar
camtrek
what do you think of it?
Old Nov 4, 2003 | 08:39 PM
Rockero28's Avatar
Rockero28
Talking filter
Well, have not had it long enough to see a diference. No highway driving, but we'll see in a couple of days.
Rock
nrbes350
21
Jul 24, 2009 09:50 AM
keviner808
May 4, 2007 03:27 AM
Mleeke
GS - 1st Gen (1993-1997)
Sep 12, 2005 01:50 PM
Cecioboe
RX - 1st Gen (1999-2003)
66
Mar 2, 2005 10:12 AM
lsy
GX - 1st Gen (2003-2009)
Mar 12, 2004 10:07 AM
