cheap horsepower (bypass mod)
Old Sep 22, 2003 | 04:30 PM
lspower's Avatar
lspower
Default cheap horsepower (bypass mod)
coolant bypass mod
http://lexusmodz.netfirms.com/GS_DIY/coolant_bypass/
just showing it in case you didnt know
Old Sep 22, 2003 | 10:09 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Yep
https://www.clublexus.com/forums/sho...ghlight=bypass
Old Sep 23, 2003 | 10:15 PM
fireballs gs400's Avatar
fireballs gs400
Question any negative effects
this is something i am planning on trying. any bad things come with this?
Old Sep 23, 2003 | 11:19 PM
NoRyceGS4's Avatar
NoRyceGS4
when i pull the hose, coolant isnt going to come gushing out is it?
Old Sep 24, 2003 | 09:58 AM
lspower's Avatar
lspower
no, no gushing of coolant happened to me
Old Sep 26, 2003 | 05:15 AM
cyclemax's Avatar
cyclemax
Default Re: any negative effects
Possibly.
As Banana stated, the system is REQUIRED to prevent icing in cold, wet weather. As the intake air expands over the throttle plate (pressure drop), it absorbs heat and cools the suroundings (throttle body). If it gets cold enough, moisture from the air can begin to freeze and build up in there, causing a restriction, rich mixture, stalling or possible stuck throttle. Tough to say exactly what temp/humidity conditions it will occur at, but obviously, this is probably not a problem in south TX.
I had an old Mits P/U that was missing the "heat riser tube" and on damp or wet cold days, the carb would ice up so much it would lose power and eventually choke out. I'd have to pull over to the side of the road and let it thaw for a couple minutes. A quick trip to Autozone and $2.50 hose fixed the problem.
I'd say that if you ever drive your car in sub 40 degree rainy or snowy weather, you should at least install a valve so you can open or close it seasonally.
nikovdh
Apr 8, 2017 01:20 AM
lexus-is2
Aug 18, 2013 05:23 PM
VNN326
Performance
Nov 14, 2007 07:15 AM
Ramon
Apr 8, 2006 07:54 AM
matt7184
Nov 22, 2001 08:46 AM
