Coil Pack Suggestions
Old Nov 27, 2019 | 08:29 AM
kiddmarce's Avatar
kiddmarce
Default Coil Pack Suggestions
When ordering a coil packs for 2000 gs300 is there a specific brand i should order ?
I've found a set of three online at partsgeek for $80 however the coils are not oem . The brand is called replacement
The oem coils are at least $130 a piece so this could potentially save me quite a bit especially since im planning on just replacing them all . Any suggestions greatly appreciated!!
Old Nov 27, 2019 | 07:06 PM
badblackgs's Avatar
badblackgs
ya you get what you pay for. the smartest thing you could do is buy denso coils.
Old Nov 29, 2019 | 08:25 AM
Angryspice's Avatar
Angryspice
I 2nd that
Old Nov 29, 2019 | 12:18 PM
sbagdon's Avatar
sbagdon
The local pick-a-part sells them for $6. The computer will tell you when they go bad, and there's 7 other cylinders?
Old Dec 3, 2019 | 04:58 PM
kiddmarce's Avatar
kiddmarce
Gs300 inline 6 and and is there away to test coil packs ?
Old Mar 20, 2020 | 09:01 AM
tu2's Avatar
tu2
When or how often should they be changed?
Old Mar 20, 2020 | 09:04 AM
coolsaber's Avatar
coolsaber
First dont buy your parts off Ebay or amazon, even if it says TOYOTA BRANDED.
Most expensive but original is gonna be the part depo online from a Lexus dealer or even toyota dealership.
Cheaper, buy the Denso branded or NGK branded part. Only two suppliers for the majority of toyota and Lexus parts anyways. You can pick these up at any local MNC (coupons now are available so evern better).
DENSO 6731203 Denso who is the OE
NGK 48905 NGK is not an OE but I`d trust this over anything called replacement as their brand
Old Mar 21, 2020 | 06:20 AM
TrueGS300's Avatar
TrueGS300
Rockauto has the NGK coils at probably the best price possible. I always go with NGK when I can. I believe they make a superior product in all that they produce. I put on a set of NGK coil packs last year as part of a complete ignition system update. Using their plugs and wires too. I have peace of mind that the ignition is as consistent and powerful as it gets for a factory style setup.
kennytbone
Aug 12, 2018 03:49 AM
HtownBlue
Dec 23, 2012 12:01 PM
shoover
15
Dec 28, 2011 02:12 PM
codemii
Jul 7, 2011 02:05 PM
sc250tt
Nov 20, 2006 01:52 PM
