Idle Problem
Old Aug 16, 2003 | 12:15 PM
MQM's Avatar
MQM
Default Idle Problem
Sorry if this was asked earlier, i did a search but my problem is a bit different...
I have a 98 gs400 and the idle is very very low, there is a little vibration, and the car is bone stock and about 200 miles till the next oil change...
The idle is low only when the car is in drive and then the AC is off, if the car is in park there is not a low idle but some vibration with the AC off, with the AC on the car in park is fine. With the AC on and when the car is in drive the idle is fine..What is the problem?...I'm going to the dealer on monday for my oil change, but im going to have then check it out...Is there a problem with my belts? the car has low miles 34k, its unheard of at this mileage...Some help please!
Old Aug 17, 2003 | 08:50 AM
MQM's Avatar
MQM
Anyone?
Old Aug 17, 2003 | 09:14 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
MQM,
This issue has been discussed at length in a number of threads - try to search for 'low idle' and you should find a bunch.
People have tried various things to fix it with varying degrees of success including cleaning/replacing the throttle body.
Here are a few I found to get you started:
https://www.clublexus.com/forums/sho...light=low+idle
Old Aug 17, 2003 | 02:15 PM
MQM's Avatar
MQM
Thanks alot, my fault i should have searched further, thanks alot!
Old Aug 17, 2003 | 02:22 PM
Default Re: Idle Problem
I don't believe there's any problem. Lexus cars are designed to be driven with the AC on all the time.
I8ABMR
Dec 17, 2012 03:08 PM
edbro
RX - 1st Gen (1999-2003)
Sep 29, 2007 09:08 AM
tanstaafl
GS - 1st Gen (1993-1997)
Feb 21, 2005 01:51 PM
lexoman
Performance
Jan 30, 2003 01:25 AM
Lvangundy
Jan 22, 2003 11:22 PM
