Does anyone know where I can find
Old May 7, 2019 | 10:25 AM
djs801's Avatar
djs801
Default Does anyone know where I can find
H&R DRM style wheel spacers? Cannot seem to find them anywhere! Looking for 15 mm
Old May 7, 2019 | 11:33 AM
2013FSport's Avatar
2013FSport
https://www.evasivemotorsports.com//...ode=HR-2065640
I'm not saying those are the ones you need. Just a source.
Old May 7, 2019 | 12:23 PM
primavera's Avatar
primavera
H&R doesn't sell DRM 15 mm for Toyota/Lexus in North America. If you want those you need to import them from Europe. H&R 3065602 or Eibach S90-4-15-009. I imported mine from Tunershop.de in Germany
https://www.tunershop.de/shop/catalo...=S90-4-15-009+
https://www.tunershop.de/shop/catalo...ult/?q=3065602
https://www.clublexus.com/forums/is-...d-h-and-r.html
You may have more luck with your search if you type in Toyota RAV4 spacers as they are exactly the same.
Old May 7, 2019 | 05:26 PM
djs801's Avatar
djs801
Thanks for the help guys I got some from performancealloy based out of the UK
Old May 9, 2019 | 04:57 AM
Zynthe's Avatar
Zynthe
Sorry for the noob question but whats the difference between regular spacer and these H&R DRM spacers?
I might be looking into getting some spacer in the near future too, so wanted to know the difference and get as much info as possible.
Thanks!
Old May 9, 2019 | 07:58 AM
djs801's Avatar
djs801
Thanks!
It’s ok bud I’m a noob myself haha but the DRM spacers have studs built into them so that they can be long enough, otherwise you have to replace the whole stud and I had a hell of a time getting that axle nut off.
Old May 9, 2019 | 08:44 AM
primavera's Avatar
primavera
Basically there are two types of wheel spacers, the ones that come with pressed in studs (H&R calls them DRM) where you take your wheels off, clean the hubs, install the spacers, mount the wheels and you're done.
The other type are the ones where you need to ****** around with your car for half a day. You will need lot more tools, remove brake calipers, remove brake line support, remove rotors, use stack of washers to install the studs, need 3lb sledge hammer to pound the stock studs out. While you hammer out the studs chances of breaking, damaging wheel hub or speed sensors are very high.
When it's time to sell the car, you'd need to go thru all this BS again... (facepalm)
Mushi31
Jun 26, 2015 04:10 PM
161r
Dec 29, 2014 02:27 PM
trinituner
Wheels, Tires & Brakes Forum
Oct 10, 2013 01:12 PM
AK-47
Suspension and Brakes
Feb 8, 2010 10:13 PM
